Installing 2012 stock radio in a pre-2012
Discussion in 'Audio & Video' started by Jerez, Apr 3, 2012.
  1. Jan 3, 2013 at 3:37 PM
    #141
    dibble9012
    dibble9012 Well-Known Member
    I noticed that the adapter has two cables (one for AM and one for FM?) Does your AM radio work? Maybe those two wires need to be spliced together? The only reason I want to retain AM radio is because it can be useful when on road trips for quick traffic info.
  2. Jan 3, 2013 at 5:07 PM
    #142
    Jerez
    Jerez [OP] SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    i only connected the bottom plug (black)
    and both am and fm work :thumbsup:
    btw, any chance you have the wiring diagram for the back up cam??
    i want to see what wires on the came are what...
    EDIT: what are you going to do with your old clock/hazard portion on your 2010?
    if youre going to sell it, let me buy it off of you
  3. Jan 3, 2013 at 5:58 PM
    #143
    dibble9012
    Here ya go:
    Rear view mirror (2010)
    Audio system w/ separate amplifier w/ backup camera (2012)
    When I was researching the project I figured out that connector ID1 is near the drivers side switch panel (by the steering wheel) for the rear view mirror video signal. If you find that connector and buy the mating piece and pins, you can create your own plug and play harness that goes from the radio to that connector. Makes the install cleaner and easily reversible. Just unplug the mirror side of the harness and plug your own in.
    About the clock panel, I might sell it once I have the whole project finished. Right now the only thing holding me up is the R15 connector (pins).
    Let me know when you get the antenna harness from China, I'll buy one off ya.
  4. Jan 3, 2013 at 6:08 PM
    #144
    Jerez
    Rod
    Ontario Ranch
    Estock
    sweet...well my truck didnt come with the back up cam (09+)
    so its all new wiring thanks
    it came in today...i got it for like $4-5 bucks free shipping ;)
    ill check it this weekend to make sure it works and its all yours bud
    those pins are killing me as well...i would have been done already. :anonymous:
  5. Jan 3, 2013 at 6:41 PM
    #145
    Jerez
    Rod
    Ontario Ranch
    Estock
    welp...somehow i got the a/v (audio/video) imput to trigger on...now to see if i can get it going again
    exactly like this for the camry
  6. Jan 3, 2013 at 6:45 PM
    #146
    Jerez
    Rod
    Ontario Ranch
    Estock
    Got it :cool:
  7. Jan 3, 2013 at 6:52 PM
    #147
    knine00
    knine00 Well-Known Member
    Hudsonville, Mi
    12 PreRunner DC TRD Sport
    Stock for now
    Bluetooth working too?
  8. Jan 3, 2013 at 6:52 PM
    #148
    Jerez
    Rod
    Ontario Ranch
    Estock
    no...i need the module
  9. Jan 3, 2013 at 7:43 PM
    #149
    dibble9012
    Sweet! I'll have to try that.
  10. Jan 3, 2013 at 9:32 PM
    #150
    Jerez
    Rod
    Ontario Ranch
    Estock
    alright im done for now...ill try some stuff tomorrow.
  11. Jan 4, 2013 at 6:34 AM
    #151
    knine00
    Hudsonville, Mi
    Stock for now
    Still trying to find just the pins but not really having good luck!
  12. Jan 5, 2013 at 9:06 AM
    #152
    Jerez
    Rod
    Ontario Ranch
    Estock
    ya same here...
  13. Jan 6, 2013 at 12:17 PM
    #153
    dibble9012
    Ok, a little more info on the pins. I found another harness (on the entune units to connect the extension module to the display module, connectors R19, R20, and E15) has the same pins. That harness has part number 86842-YY020 on the label. A quick google search turned out empty handed but I'm going to contact a dealer and see if I can order that part separately. It looks promising as the repair manual has "repair or replace harness" if the extension module has errors.
  14. Jan 6, 2013 at 12:42 PM
    #154
    Jerez
    Rod
    Ontario Ranch
    Estock
    Nice!! I need to get on this radio ASAP...I just don't have time for stuff anymore :pout:
  15. Jan 6, 2013 at 1:11 PM
    #155
    dibble9012
    The pins are also the same as the ones for the S23 connector on the amp. BUT not the same pins as that connector on the aftermarket bazooka harness that I used (seen here).
    Jerez, did you get my PM regarding the antenna adapter?
  16. Jan 6, 2013 at 1:57 PM
    #156
    jaymay82
    jaymay82 Well-Known Member
    '13 MGM TRD Sport DCSB
    Do you guys know if the 2013 has a video input?
  17. Jan 6, 2013 at 2:39 PM
    #157
    Jerez
    Rod
    Ontario Ranch
    Estock
    Ya, you didnt get my reply back??
    My radio is from a 2013
  18. Jan 6, 2013 at 2:45 PM
    #158
    dibble9012
    No didn't get your reply.
  19. Jan 6, 2013 at 3:18 PM
    #159
    Jerez
    Rod
    Ontario Ranch
    Estock
    Weird :confused: that It can probably be shipped to you in a small box from the post office since it's a super small plug anyways...
    Ill check tomorrow after work so it can be sent Tuesday or wed
  20. Jan 6, 2013 at 3:52 PM
    #160
    dibble9012
    FOUND THE PINS
    At least it looks like, I'll confirm once I receive them in the mail. Look here.
    Both the toyota connector and pins are available on mouser.com
    R17 connector
    Pins
    Now that I found that series of plug on mouser.com, the whole project became a WHOLE lot easier and cheaper. Most of the connectors and pins can now be found on mouser by looking at that series.
    i/o likes this.
