Installing 2014 Tundra OEM Coilovers in a 2013 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wasatch, May 4, 2015.
  1. May 4, 2015 at 8:59 AM
    Wasatch
    Wasatch [OP] Well-Known Member
    Searched around and only found information about this for 1st Gens.
    Can it be done? Are the bolt patterns-sizing the same?
    Any insight is appreciated.
    Thanks!
  2. May 4, 2015 at 9:01 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Not made for our trucks. Wrong dampening, wrong springs.
  3. May 4, 2015 at 9:04 AM
    Wasatch
    I understand, but with a winch-bumper and some seriously maxed out OEM Tacoma struts, I can pick up a set of Tundra TRD Coilovers inexpensively.
    So back to my question:
    Are the bolt-patterns the same?
    Will they fit?
  4. May 4, 2015 at 9:24 AM
    Wile
    Wile Well-Known Member
    Tim
    New Mexico
    08 4x4 DC TRD Offroad
    Pioneer AVH-5600BHS, ScanGauge, Wet Okole Seat Covers, Allpro Aluminum front bumper, Allpro Aluminum IFS skid plate, Allpro APEX rocksliders, Warn 9500s winch
    Curb weight of a tundra is 5800lbs. A Tacoma is 4800lbs. That's going to be a rough ride even with a tacoma full of armor.
  5. May 4, 2015 at 11:35 AM
    Wasatch
    OK. I understand. Ride aside:
    Will they fit?
  6. May 5, 2015 at 3:34 PM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    Don't think its possible but good luck to you if you can pull it off!
  7. May 5, 2015 at 3:47 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    I think you'll need to compare them in person.
  8. May 5, 2015 at 8:39 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    someone say yes. I think we'll be hearing the same questions until someone does.
    T4RFTMFW likes this.
  9. May 5, 2015 at 8:57 PM
    DaVikes
    DaVikes Well-Known Member
    Ross
    Denver
    Colorado Sports Car
    Arb front bumper, warn winch, All Pro rear bumper, OME up front, OME and All Pro Standard in Back, ARB locker, 34 x 10.5 KO2's, 17" Level 8 Trackers, and fancy single piece driveshaft.
    It might be easier to compare the aftermarket coilovers for each truck online somewhere. Hopefully you could find dimensions for them. Otherwise you're just going to have to go measure them.
