Installing 5100's and need feedback on issues
Discussion in 'Suspension' started by headhunter247, Nov 23, 2009.
  1. Nov 23, 2009 at 6:41 PM
    headhunter247
    headhunter247 [OP] Well-Known Member
    St. Louis, MO area
    13 Taco Double Cab TRD
    Bilstein 5100's all around, front set at 2.5", Toytec AAL, 265/75/16 Duratracs, Pro Comp 5001, Weathertech's, AVS In Channel Visors, Nokya Hyper Yellow fogs, CB Set up, Color matched grill surround, ATC Camper Shell with Yakima Racks, SOS Concepts Regular Rear Bumper.
    Hey all...just ordered my billies and AAL today. I need to know if there are any issues that you had when you did this yourself? Any helpful hints to make this go as smooth as possible would be greatly appreciated. Thanks in advance.
  2. Nov 23, 2009 at 6:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Dont let Pep Boys install the spring on the shock. Or else you can be wearing one of these....If your lucky.
  3. Nov 23, 2009 at 6:45 PM
    headhunter247
    St. Louis, MO area
    HA! Thats classic. Id have to give someone a shiner for that..it will be my local greasemonkey compressing them on.
  4. Nov 23, 2009 at 6:48 PM
    RI06TACO
    RI06TACO Well-Known Member
    Jeff
    Rhode Island
    06 Tacoma Sport
    just make sure you follow the instructions..and take everything apart on both sides before you try to remove stock shock..The sway bar needs to be un connected on BOTH sides before you remove the shock..
    I'll post some pics on another thread of how mine came out..
    AND GET SOMEONE TO DO THE SPRINGS FOR YOU!!!
  5. Nov 24, 2009 at 5:13 AM
    headhunter247
    St. Louis, MO area
  6. Nov 24, 2009 at 5:17 AM
    Brunes
    Brunes abides.
    Rotorhead
    Make sure the guy doing your springs aligns the top plate studs with the lower shock mount properly. Jan has a diagram of how it's supposed to work.
    Take your time- Don't be afraid to remove parts if they are in the way- Take your time- and Enjoy working on it!!
  7. Nov 24, 2009 at 5:32 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    08 Tacoma 4x4 TRD V6 SR5
    Rear Leaf Spring TSB, Front Bilstein 5100's set to 1.75, Goodyear Wrangler DuraTrac 265/75/R16 tires, Black WeatherTech Floor Liners, aFe Pro Dry S air filter, lighted 4x4 switch......
    Make sure the driver's side coil spring goes back on the driver's side. It's supposedly built heavier.
  8. Nov 24, 2009 at 5:43 AM
    headhunter247
    St. Louis, MO area
    Edit: Is this what you are talking about?
  9. Nov 24, 2009 at 6:04 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    if not aligned correctly you can put the top of the Coilover in the coil bucket, loosly tighten the 3 top nuts and turn the bottom of the coilover with a large wrench to line things up.
    Much easier then going back to the shop 2-3 times........
  10. Nov 24, 2009 at 6:07 AM
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    08 V6 4x4 DC TRD, 6spd
    TRD Supercharger, TRD CAI, Sirius, Rear TSB, Front 5100 with Eibach coils, 1.5" AAL, URD short throw, fog light mod, weather tech liners,
    ^^that's what I did^^, I did try and line it up pretty close, but had to do a little adjusting on the truck.
  11. Nov 24, 2009 at 6:21 AM
    Brunes
    Brunes abides.
    Rotorhead
    That's it. I put the first on together wrong...looked at the FSM and got the second one spot on and then fixed the first one.
  12. Nov 24, 2009 at 8:09 AM
    headhunter247
    St. Louis, MO area
    Cool, I dont think this should be too hard. I have a friend helping thats pretty good at all this so I should be good. If anyone else has anything to chime in with, please do so.
  13. Nov 24, 2009 at 8:32 AM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    Do it your self on the springs its easy. Just get one of these.
    Took me about 3 hours.
  14. Nov 24, 2009 at 8:46 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    In your pic, it the spring seat on the 5100 is upside down. I hope you didnt install them like that.
  15. Nov 24, 2009 at 8:50 AM
    Hoyal
    Devin
    2013 Tundra
    No I installed the way It was so posed to we caught that ask Brandon (Blowham) it was funny I was like WTF that dosent seem right lol he was quality control and he was slacking! I actually had someone with me that is a mechanic but if I were to do it again I could have easily done it with just the advice you gave me through PM.
  16. Nov 24, 2009 at 9:40 AM
    Rustyota
    Rustyota well.....
    Central Coast, CA
    08 4x4 DC long bed
    debadged, rear spring TSB, leveled with Bilstein 5100s at 1.75", Goodyear Duratrac 265/75/r16, Leer shell with Yakima rack
    I "borrowed" a spring compressor from Autozone ($50, but refunded when you bring it back) and it was pretty easy. Literally did this last night, took a little over an hour, but I've had this front end apart before so it was probably quicker than if it was my first.
    Couple words of advice--First, check and make sure you have ALL the parts before you start. It's a long story, but it sucks when you have everything apart and realize that you have to put it all back together and wait for FedEx to bring a missing part...
    Second, have someone help you when you pull the struts and when you put them back. The helper uses a pry bar (with wood block of course) to push the lower arm down while you pull the strut out and down in front of the lower arm. The strut will slide right out (downward) in between the lower arm and the steering control arm. Way easier than taking it toward the back, and you don't have to remove brake lines and all.
  17. Nov 24, 2009 at 9:40 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Whew. Good to hear. :)
  18. Nov 24, 2009 at 7:37 PM
    Rustyota
    Rustyota well.....
    Central Coast, CA
    08 4x4 DC long bed
    I took some pics of the removal/reinstall and could post them if you're interested. It's not that bad...
  19. Nov 24, 2009 at 7:57 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    just got back from the shop after putting 5100's and the eibach coils in myself.
    i removed the sway bar, disconnected the tie rod ends and lower ball joint mounts.
    this way you can move the whole hub assembly back and out of the way and have tons of room to work and move the coil assembly out/in to place.
    pry down on the lower control arm and slide the whole unit out.
    i had to disassemble my old coils to get the top plates for the spring and coil setup. i was using a loaner spring compressor set from a parts store (which i don't think was rated for anywhere near the spring rate of even the stock coils!). it can be a pain but just takes a little patience. this will most like be the hardest part of the install.
    alot of people say to get them done by someone else, but it is important to align the top plate properly with the lower shock mount, or you'll be cursing up and down trying to get it all back together
    just remember to anti-seize everything when it goes back together! you'll thank yourself in the future.
  20. Feb 10, 2010 at 9:09 PM
    texastacobueno
    texastacobueno Effin A Cotton, Effin A
    Andy
    College Station, Texas
    08 4x4 Sport
    Pop N Lock - Westin sportsman guard - Hella 500 fogs - extra D-rings - Mag Lite mounts
    mk I just ordered my eibach and billy's today so i'm about to begin prepping for the install, and i see that allignment diagram shown above but what i dont understand is which side the 2 studs that are parallel go on. do they face the inside of the truck or the outside?
