Installing 5100's with rear blocks
Discussion in 'Suspension' started by nytmarecoma88, Mar 28, 2010.
  1. Mar 28, 2010 at 2:56 PM
    nytmarecoma88
    nytmarecoma88 [OP] Well-Known Member
    07 tacoma
    Tonnuea Tint euro Tail lights halo head lights billet grille- black debadged black powdercaoted 17's "knight rider" mod aero turbine exhaust black bull bar multicolor halo fogs
    and i need a 'how to' on installing the blocks, i think i have the main idea, just seeing if anyone has any pointers or tips that would make it easier??
  2. Mar 30, 2010 at 5:51 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Just did it last weekend on my 05 dbl cab 4x4. Easy, just take your time.
    1) jack up and place rear end on stands.Make sure to place floor jack under axle pumpkin.. Remove wheels
    2)unbolt bottom shock mounts, remove U-bolts, unbolt the brake lines from axle to give some slack.(2-3 bolts per side)
    3)SLOWLY lower floor jack under differential until there is enough gap to slide block between axle and springs. Blocks have centering pin so it only goes in one way. Slowly raise floor jack but make sure the springs line up with the centering pin with the block. You may have to gently pull on the springs or axle to pop in place. Only install one side at a time !! Install new U-bolts and bolts. You can torque to specs after installing other side. Toytec recommends 80 ft/lbs but some members have stated 37 lbs. I did about 60lbs. Re-install brake line bolts,wheels,shocks,torque u-bolts and you are done.. Re-torque u-bolts after about 10 miles...Search on TW, there is an excellent writeup w/pics under Toytec coilover install..Good Luck !
  3. Mar 30, 2010 at 7:01 PM
    PreRunner
    PreRunner Well-Known Member
    step 1: don't
  4. Mar 31, 2010 at 4:05 AM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    Step 1 revision. I meant to say to place jack stands on your frame not your rear end. The floor jack under the differential. My Bad !
  5. Mar 31, 2010 at 6:38 AM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
  6. Mar 31, 2010 at 8:08 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
  7. Mar 31, 2010 at 11:25 AM
    nytmarecoma88
    07 tacoma
    thanks guys, i just got my 5100s in today, so ill be doing this on the weekend
