Installing 5100's without a Spring Compressor Video
Discussion in '1st Gen. Tacomas (1995-2004)' started by chickenhead, Nov 28, 2011.
  1. Nov 29, 2011 at 8:58 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
  2. Nov 29, 2011 at 9:55 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Hmm...very interesting. Seems pretty safe to me. I might give it a try next time I do a suspension job.
    I have a pair of the harbor freight compressors. I have used them more times than I can count doing suspension work on my vehicles and friends' vehicles. I've never had a failure with them. The key is make sure they're evenly spaced on the spring and use air tools. I did the front suspension on my truck in about an hour by myself with my compressors. I didn't remove the LCA though, I seperated the UCA ball joint from the knuckle.
  3. Nov 29, 2011 at 12:17 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    this way seems a lot safer to me, even if that coil found it's way off the shock, it's going straight up into the truck, nowhere near anybodies head...
    the upper control arm would stop it from coming towards you.
    seems like the way to do it to me!
  4. Nov 29, 2011 at 1:14 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
  5. Nov 29, 2011 at 1:17 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    It is different because you're compressing a not-yet-attached spring.
    Again, I'm not saying "don't do it.". I'm saying "be careful."
  6. Nov 29, 2011 at 2:29 PM
    chickenhead
    chickenhead [OP] Member
    Oklahoma
    02 TRD DC
    My only concern is these cheap ass chinese made jacks these days. I cant find an older floor jack to buy anywhere unless their $600. Hopefully the new ones made today wont be defective.
  7. Nov 29, 2011 at 2:41 PM
    anormis
    anormis Well-Known Member
    Anthony
    St. Charles MO.
    BarcelonaRed 2010 D.C V6 4.0 Liter 4x4
    Hunter trucks brush guard, pcd performance chip, tailgate theft mod,blacked out badges, painted engine cover, black tail lights, modded mud flaps, painted black grill, seat belt beep mod, rear TSB!.yellow fogs red led map lights. Painted switches black, painted hood scoop, black center console and overhead console. Black wheels! Red calipers.
    subbed
  8. Nov 29, 2011 at 6:51 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
  9. Nov 29, 2011 at 7:51 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    I'm working on ordering my 5100's and eibach's. I will definitely be doing this!
  10. Nov 30, 2011 at 6:37 AM
    macgyver
    Brad
    Canton, GA
    My $35 Harbor Freight 2.5 ton jack has served me well for the last 6 years. It leaks a little oil and requires a refill every so often but thats it. It's chinese made and has lifted more cars and trucks than I can count.
    The key with buying stuff from them is the less moving parts, the better. Not all Chinese stuff is crap.
  11. Nov 30, 2011 at 12:54 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Bottle jacks seem to hold up better than floor jacks. My 14 month old AC/Delco floor jack just started having a slow pressure leak, and easing the load down instead of holding it. :mad:
  12. Dec 13, 2011 at 9:41 AM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    UPDATE:
    I installed my eibach coils on my 5100's at .85 and used this method, it was extremely easy, completely safe, and the only way i'll be putting coils on from now on.
  13. Dec 13, 2011 at 9:59 AM
    pinchetaco
    pinchetaco Well-Known Member
    Winston Salem, NC
    06 Taco 6 inch ProComp Lift 35's
    6 inch ProComp Lift, 35x12.50x18 Red Letter Generals, ProComp Wheels, Debadged, Black Headlight mod, Dome Light Mod, Trailer Plug Relocated
    Damnit I just paid a shop to do press mine. I'll be doing this method from now on... Seems pretty safe to me spring compressors are pretty dangerous and if you were to let that jack down to fast the shock would stop most of the force from the spring and like it was stated before it would go into the wheel well instead of your pretty face
  14. Dec 13, 2011 at 11:38 AM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    it also didn't take much compressing to get the top nut on. had something let go, the UCA would have held the shock and coil in place, especially since you don't compress until you have the lower shock mount in.
  15. Jun 6, 2012 at 6:29 PM
    #35
    jerlane
    jerlane Well-Known Member
    Minneapolis, MN
    '11 TRD Sport DC LB 4x4
    I'm getting ready to install my new billsteins using this method and I was wondering how important it is to use a torque wrench when putting everything back together. Is it bad to just crank everything tight by hand or with an impact wrench? I've never done this type of project before.
    Thanks in advance!
  16. Jun 7, 2012 at 12:17 AM
    #36
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Not trying to be a dick, but by the very question you ask, the first thing I think is SHOULD you use this method, c'mon brother you're asking if its bad to tighten by hand or use an impact ? Or the importance of torque wrenches... These are things I'd assume you are already familiar with
    I'm not putting you down just trying to get a handle on your mech ability is all....
    But the willingness to try & maybe learn a thing or two is always good in my book....:)
  17. Jun 7, 2012 at 4:42 AM
    #37
    jerlane
    Minneapolis, MN
    Thanks for the lecture. That was almost helpful. I guess I should never try to expand my skill set.
  18. Jun 7, 2012 at 5:21 AM
    #38
    kingston73
    kingston73 Well-Known Member
    eastern MA
    09 SR5 4.0L 4x4
    dude, don't get angry, 4wd was trying to help you out.
  19. Jun 7, 2012 at 5:36 AM
    #39
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Bro', read the last couple of sentences of my post to you , & for what its worth if we were just talking about a simple procedure I probably wouldn't have responded, but doing struts is serious shit no matter HOW easy it looks , I've done many struts with compressors & the way described above, if your up to it have at & I apologize, like I said not trying to lecture/put down/ridicule,etc; good luck
    :notsure:
  20. Jun 7, 2012 at 8:08 AM
    #40
    jerlane
    Minneapolis, MN
    OK, OK... no harm, no foul. I'm mechanically inclined, I just don't have a lot of auto experience which is why I'm looking for advice here. People have posted that some have used torque wrenches while others have not. I'm trying to do it the right way.
    Thanks for the help!
