Installing 5100's without a Spring Compressor Video
Discussion in '1st Gen. Tacomas (1995-2004)' started by chickenhead, Nov 28, 2011.
  1. Jun 7, 2012 at 8:13 AM
    #41
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    Using a torque wrench for some things is more important than others, but it's generally a good idea to use one if the manual calls for a specific torque setting. Just make sure you buy a GOOD one, a torque wrench is definitely not a tool you want to go cheap on. I'd be willing to bet money there are almost as many people who have broken bolts using a cheap torque wrench as there are people who weren't using one at all.
    I have to admit, when I first read the post I was skeptical but after watching the video it really does seem safer than using a spring compressor, easier too. When I did mine one of the most difficult parts was getting the spring/shock assembly back into place, so using this method would have saved me a decent amount of effort and time. Thanks for posting.
  2. Jun 7, 2012 at 9:52 AM
    #42
    jerlane
    jerlane Well-Known Member
    Minneapolis, MN
    Thanks, that's the type of info I'm looking for. I've been reading reviews here on torque wrenches and there definitely seems to be mixed reviews on brands like Craftsman. I'd rather not spend $150-$200 on one if possible. Anyone have any suggestions for a good, reasonably priced (under $100) torque wrench?
  3. Jul 13, 2013 at 8:38 PM
    #43
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    I may try this as I am putting the .5" spacer on my 884s. Need to take the spring off to install the longer bolts.
    Anyone know the torque specs for the LCA bolts and the alignment bolts (being loosened)..
  4. Jan 12, 2014 at 12:49 PM
    #44
    pahennessey
    pahennessey Well-Known Member
    Patrick
    Denver, CO
    2013 Double Cab TRD OR
    Wheeler's HD 5 Leaf Pack, Bilstein 5100's @ 1.75
    I know that this is an older thread now, but I thought I'd give my .02.
    I used this method yesterday to when I installed Bilstein 5100s set at 1.75 and it was completely painless and straight forward. I highly recommend this method for even people with novice mechanical ability.
  5. Jan 26, 2014 at 12:43 PM
    #45
    FishOn209
    FishOn209 Member
    Elk Grove, Ca
    2005 PreRunner DCLB
    Can this method be use to take the complete with the topper out too?
  6. Jun 29, 2014 at 6:08 PM
    #46
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I am going to bump this because people need to know about this..
    Seriously, if you are using a spring compressor you are doing it WRONG.... i have used a spring compressor for quite some time on struts every time the 1st gen prerunner taco my dad drives needed shocks.
    I decided to try this on my 2013 when installing my 5100's @ 1.75 and i gotta say holly hell.... talk about EASY and MUCH MUCH safer than any janky spring compressor.
    Yes.
  7. Jun 29, 2014 at 6:31 PM
    #47
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    FYI this is how typically rear lift springs are installed in 4Runners/FJs. Put a jack under the axle, remove the shock (which is the droop limiter), and slowly lower the jack until the spring is free:
    (go to 24:30):
    http://www.youtube.com/watch?v=m9-0hMzv_RU
  8. Jun 30, 2014 at 6:26 AM
    #48
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    I tried this and almost took off a limb. Probably did it wrong :notsure: but not recomended IMO.
  9. Jul 4, 2014 at 8:42 AM
    #49
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    What was the cause of your near accident?
    I'm considering this method to swap my coils next week
  10. Jul 4, 2014 at 11:34 AM
    #50
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Yeah chris ya must've done something wrong, easily the safer of the standard R&R of struts....
    I've changed many a tacoma coil using compressors & after doing it without the compressor, I'll never go back to one..
  11. Jul 4, 2014 at 11:47 AM
    #51
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I have no idea :notsure:. One of the local guys was coaching me through (did it on his 2nd gen twice. I think I wasn't able to get the spring completely unloaded. Anyways, the assembly shot out and something flew about 20ft. To this day I dont know what it was :eek:
    It was during a mod meet and I forgot who was helping but we got lucky but I almost killed EL TACOROJO. Ryan (wrmathis) was laughing his ass off.
  12. Jul 4, 2014 at 4:24 PM
    #52
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Ahhh, bet i know, you didn't have the jack quite under the LCA or not enough jack pressure under it & you removed the center nut allowing the spring to unload on its own (no lowering of jack to slowly de compress)
    think maybe this ??:)
  13. Jul 6, 2014 at 7:44 AM
    #53
    TIPICOTACO
    Tyler
    nw nj
    Ok I'm gonna give this a shot in the next couple days. The video is on a 2nd gen, anything different that I need to know to do this on my '01 ?
  14. Jul 6, 2014 at 4:21 PM
    #54
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    We had it compressed just fine. I think the issue was when we slowing released the jack, it didnt go down enough to unload the spring fully :notsure:. Honestly it was a while ago and I was just happy to walk away from it.
    I prefer a decent set of spring compressors. The autozone ones worked on the 620 lb springs just fine...
    If you know what you are doing and carefull, its easy, but the risk is a bit higher if you ask me.
  15. Jul 6, 2014 at 7:34 PM
    #55
    TIPICOTACO
    Tyler
    nw nj
    We'll I went ahead and used this method today to swap my coils from the OME 881 to 883s
    The decompression of the coils went perfectly, super safe and easy. I won't even consider using those sketchy coil compressors ever again.
    I didn't have to loosen the LCA bolts at all, but it was a bit tricky to get them pushed down far enough to get the strut coil assembly back in and the bolt holes lined up. Nothing a hammer/ screwdriver/ and pry bar couldn't handle. Maybe had I loosened them it would have been easier but oh well..
    My biggest issue was getting the F'n top nut off the shock shaft on the PS.. ended up cutting it off and running out to get a new nut.
    All in all, it was very straight forward and I'm very grateful for coming across this method!
  16. Jul 8, 2014 at 9:12 PM
    #56
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    We used the method with the last mod day. It is easy, also easy to forget the energy there and not respect it. Can't see how it would fly out past the UCA, but can see a finger getting jammed , or worse.
  17. Aug 27, 2014 at 10:00 AM
    #57
    jwinky
    jwinky Well-Known Member
    oklahoma
    2006 Access cab 4x4 5 speed
    5100's with OME 885 coils, Wheeler's 2" AAL
  18. Aug 27, 2014 at 10:11 AM
    #58
    muddog67
    muddog67 Well-Known Member
    When I put my 5100s in, I stood in front of the truck ( with the floor jack handle facing out the front of the truck and not next to the wheel well , never stand next to the wheel well when doing this ) and let it down very slowly . And I had no issues and I got the idea off that Video . The key is having a good floor Jack that will not go down fast when releasing it to go down .
  19. Aug 27, 2014 at 6:30 PM
    #59
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    When me and my dad installed the 5100 we didn't loosen the lca bolts. It sucks and is much harder this way but there in no need for an alignment afterwards. We just had to pry down on the lca hard enough to loosen the bolt connecting the shock to the lca and then pop the lower part of the shock off of the lca. Its harder get them in as well, trying to align the bolt holes up while pring on both the lca and spring is tuff, but its all can be done.
  20. Sep 9, 2014 at 11:40 PM
    #60
    Dragons Taco
    Derek
    Cary/Raleigh NC
    Tighten the bolts FTMFW rock and roll!
