Installing 5100's without a Spring Compressor Video
Discussion in '1st Gen. Tacomas (1995-2004)' started by chickenhead, Nov 28, 2011.
  1. Apr 20, 2019 at 7:40 PM
    #141
    Lynno
    Lynno Member
    Lynno
    2004 Double Cab 4X4
    None at this time
    WOW, seems like a job I do not want to accomplish. I do want to do off road driving but not heavy duty. I will check out a shop price to install and go from there. I did buy a set of spring compression tools but having second thoughts. Thinking of the Rancho RS5000X set of 4 (four) . Thanks guys
  2. Apr 20, 2019 at 10:36 PM
    #142
    underaroof
    underaroof ember
    Eastern Sierra
    2004 Xtracab 4x4 V6 TRD
    This is an old thread, but still relevant.
    I rented spring compressors from a local auto parts store and it took very little effort to change them out. And it was free.
    I wouldn't hesitate to do it again with the proper tools.
  3. Apr 21, 2019 at 6:56 AM
    #143
    WileECoyote
    WileECoyote Well-Known Member
    SoCal
    1st Gen 4WD 2.7L RegCab
    Yaesu FT-1900R w/ 2m/70cm Comet SBB-224 antenna, Cobra 19 DX IV w/ 4ft Francis CB24 Hot Rod antenna, Uniden Bearcat BC355N 800Mhz mobile scanner (analog), an external BNC mount routed to inside the cab for a handheld fire/police scanner or HAM HT's, Rancho RS5000 front struts and rear shocks, 6in KC Daylighter (pencil beam), 15x7 Black Rock Wheels Series 942, 31x10.50R15 Firestone Destination AT, fog lights, COBRA antenna hood mount (this is used to mount the GoPro on to)
    Agreed, old thread or not it is definitely still relevant.
    I did mine without the spring compressors and actually couldn't feel more safer about it. :thumbsup:
    I did mine with stock springs, but can't vouch for "heavier" springs. In that case though, I would trust doing it with this method (i.e. without spring compressors) even more so!!!
  4. Sep 22, 2019 at 8:01 AM
    #144
    EnginerdPA
    EnginerdPA Member
    Sorry to bring back an old thread but I did this yesterday and was wondering if it’s possible to pass the strut shaft too far up past the mount or is it limited on how far it will go? I couldn’t really tell when I did it so I compressed it to the point where all of the threaded section of the strut shaft came out above the mount.
  5. Jan 6, 2020 at 5:23 PM
    #145
    Cascadification
    Cascadification Member
    2015 Sport Double Cab 4.0
    I've got some 5100s with OME 885s already assembled and am looking to install this weekend. Since this will lift the front end a couple inches will the cam alignment be the same when I put it all back together or will it be significantly off from the markings I make because of the lift? I really don't want to disassemble everything from the UCA to do this job. Thanks in advance!
