Installing a backup camera
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vitamin J, May 30, 2018.
  1. May 30, 2018 at 8:51 AM
    Vitamin J
    Vitamin J [OP] USN Vet
    Oklahoma City
    2014 White DCSB PreRunner Texas Edition 4.0L V6
    Just cosmetic: Window Tint, radio knobs, temp control knobs, Tech-Deck, Tonneau bed cover, tail gate lock, de-chromed all badges inside and out, installed back up camera and custom bedside decals.
    I want to install a backup camera, but not sure if my tailgate is already prewired or if it will even display on the OEM monitor....I do see a conduit coming out the bottom of the tail gate....is there a sure fire way to tell if it will work....is it a plug n' play?
  2. May 30, 2018 at 10:07 AM
    MA_TACO
    MA_TACO Well-Known Member
    Wesley Chapel, FL
    Is it an aftermarket camera? Unless the factory radio has an RCA plug for the camera(i doubt it) and a way to trigger the display then it probably wont work with factory radio unless you're handy with wiring. I just installed a backup camera on mine but I'm using a Kenwood head unit and aftermarket cam.
  3. May 30, 2018 at 10:11 AM
    MA_TACO
    Wesley Chapel, FL
    My Taco didn't have any harnesses prewired into it. I hade to run an RCA plug from the hitch all the way to the head unit. There's a big rubber grommet behind the utility box under the rear seat that i used the run the wire into the cab.
  4. May 30, 2018 at 10:14 AM
    incredibillhulk
    incredibillhulk Don't Panic
    Bill
    North Carolina
    2013 DCSB MGM
    In the works.
    When people refer to a vehicle being pre-wired for video, the connector you are looking for is actually underneath the truck on the passenger side. If you see that, check out part number 250-8412 on this page and you're ready to go (this is my employer - let me know if you have questions): http://www.rostra.com/add-camera-to-factory-lcd-screen-in-car.php#2508412
    Vitamin J[QUOTED][OP] likes this.
  5. May 30, 2018 at 10:17 AM
    incredibillhulk
    Bill
    North Carolina
    2013 DCSB MGM
    In the works.
    Also, here's an install video for that product:
    Vitamin J[OP] likes this.
  6. May 30, 2018 at 11:48 AM
    Vitamin J
    Oklahoma City
    Looks easy enough...if the cable is there, then i'm gonna order an OEM camera like in that video. :thumbsup:
