Installing a cam lock for your bedside storage mod
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Caliph420, Aug 17, 2016.
  1. Aug 17, 2016 at 6:54 AM
    Caliph420
    Caliph420 [OP] Well-Known Member
    Washington
    2012 SR5 2.7 AC 4x4 Manual
    I had this in my build page but thought other people may be interested in the process I used to key my cabinets
    Note: Buy 2 keyed alike locks so you only have one key for the 2 cabinets, I ended up buying them online since the hardware store didnt have them to purchase like that
    1) Remove actual cabinet box from bed
    2) Take door to cabinet and use a [​IMG] step bit to drill a hole in the center the diameter of your [​IMG] file cabinet lock. You want it to fit snugly so the hex nut will pinch the plastic good when it is tightened and most come with a little metal circle with 2 sharp ends which hold the lock firmly in place once it is tightened down with the hex nut
    3) Put back the newly keyed door [​IMG] into the original place in the cabinet and put some caulking or paste on the [​IMG] ^ tab which sticks out the right. When you take the key and turn the lock it will leave a mark on the inside of the cabinet where you need to drill a slot.
    4) Drill a series of holes like this [​IMG] in the top of the cabinet so the lock can engage the top part of the cabinet when it is closed and lock and is secure. This part is super critial to meaure correctly because even a little play messes up the whole process. Also the cabinet boxes are fiberglass and no fun to drill in. I filed down the edges of the drilled holes so it makes a smooth slot like this [​IMG] The opening is larger at the front so the tab can catch the slot easier and then narrows so it fits snugly once its in the locked position. Very possible to jack up the whole thing up by not making the slot precisely where it needs to be to have a smooth action on the lock, just a heads up.
  2. Aug 17, 2016 at 9:40 AM
    Rambeaux
    Rambeaux Diäb soulé
    Jerkwater, USA
    2016 Blk TRD Sport 4X4 DCSB
    Cracked W/S
    Nice job!
    Btw, at first I thought you keyed your bed with some cabinets. Glad that wasn't the case.
  3. Aug 17, 2016 at 11:12 AM
    mcdean
    mcdean Well-Known Member
    San Jose, CA
    2016 DCLB TRDOR 4x4 A/T
    LED int lights, Morimoto HID lows, Philips LED fogs
  4. Aug 17, 2016 at 11:18 AM
    Caliph420
    Washington
    :welder::sawzall:wheres the fun in that? :boink: if you see my build page Im not really about droppin tons of cash buying stuff for my truck, I have made a bunch of things for it though, backwoods custom stylie ;)
    ST77, MadDaddy, FHC and 3 others like this.
  5. Oct 6, 2016 at 6:16 PM
    crymes
    crymes Well-Known Member
    Cameron
    CT
    2017 TRD OR DCSB QS
  6. Dec 4, 2016 at 4:03 PM
    Dawnpatrol
    Dawnpatrol Well-Known Member
    PNW
    Thanks Caliph420 for the great tip! If I pull the trigger on that 2017, this will be my first modification!
    Caliph420[OP] likes this.
  7. Dec 8, 2016 at 6:46 PM
    tacitos
    tacitos Tah-Key-Toes
    16 TRDORDCLBJBL
    If you look around enough you can find some lock kits that fit the standard hole avoiding the need to drill. I used mailbox locks for mine, no drill required.
    -TacoMatt, coma toy and t4daddy like this.
  8. Dec 20, 2016 at 11:41 AM
    JWolfUO
    JWolfUO Well-Known Member
    Jon
    Tigard, OR
    2017 White Tacoma DCSB 4x4 SR5
    You have a link or more info on these?
  9. Dec 20, 2016 at 11:59 AM
    Hogpauls
    Hogpauls Hmmmmmm.
    Near Boise
    '16 Tacoma BBP TRD OR Dbl cab mt ftw
  10. Dec 20, 2016 at 12:28 PM
    tacitos
    16 TRDORDCLBJBL
    JWolfUO[QUOTED] likes this.
  11. Dec 20, 2016 at 12:40 PM
    JWolfUO
    Jon
    Tigard, OR
  12. Dec 20, 2016 at 12:46 PM
    JWolfUO
    Jon
    Tigard, OR
    tacitos[QUOTED] likes this.
  13. Dec 20, 2016 at 2:17 PM
    Caliph420
    Washington
    There are def advantages to replacing the knobs with locks as far as simplicity. The way I did it you could easily jack it up so it doesn't work good or at all. My main thing was wanting 1 key for 2 cabinets and 1 lock to open each cabinet for easier access.
    RobP62 likes this.
  14. Dec 20, 2016 at 2:57 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I would do this if they weren;t plastic, so easy to bypass the lock.
  15. Dec 20, 2016 at 3:01 PM
    Caliph420
    Washington
    I'm targeting that jerk walking by my truck in a parking lot or while my truck is parked somewhere in the woods. Anyone who really wants to get in there is gonna do it. Its just a deterrent against lazy thieves.
    AMC×3 and JoeCOVA[QUOTED] like this.
  16. Dec 20, 2016 at 3:11 PM
    JWolfUO
    Jon
    Tigard, OR
    I'm a lazy thief. I only steal ideas.
  17. Dec 20, 2016 at 3:14 PM
    Caliph420
    Washington
    Thank you Tacomaworld for that. Great times browsing all this info and dreamin up random crap to change on the Taco.
    Jsevert2023 and JWolfUO[QUOTED] like this.
  18. Jan 10, 2017 at 8:21 PM
    Taco351
    Taco351 Well-Known Member
    Robert
    NLR/Sherwood
    2017 Tacoma Double Cab 4X4 TRD Off-Road White
    K&N air filter/LED lights/Magna Flow Muffler/TOYO AT2 Tires and lots of fun stuff.
    I just noticed the earlier Tacoma's have these extra storage pockets close to the wheel wells. Some are just in front and some are almost right over the wheel wells. I am thinking about adding these. Has anyone done this or does anyone know the part numbers? Thanks! I think 2014 and earlier.
    Mr. Nobody likes this.
  19. Mar 27, 2017 at 10:08 PM
    jessetoedtman
    jessetoedtman Well-Known Member
    Jesse
    San Diego
    2010 Tacoma SR5 DCLB 4x4
    nice idea- I will try this one weekend
  20. Mar 28, 2017 at 4:02 AM
    Taco351
    Robert
    NLR/Sherwood
    They are about $85 each
