Installing a Currie Ford 9" in a Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jberry813, Apr 24, 2018.
  1. May 18, 2018 at 6:25 AM
    #81
    jberry813
    jberry813 [OP] Professional Fluffer Moderator
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    35 spline axles and third member.
  2. May 18, 2018 at 6:36 AM
    #82
    ericd
    ericd Stuff
    Eric
    las vegas
    2013 DCSB 4x4 OR
    Thanks. I figured the spiders would have to match.
  3. May 23, 2018 at 6:42 PM
    #83
    bski22
    bski22 Shaka Zulu \000/
    Rob
    Toyota
    Dang. Sick write up.
  4. Jun 13, 2018 at 4:19 PM
    #84
    desperado915
    desperado915 Well-Known Member
    Very nice writeup and I love the Currie 9" Axle. Big money, but big reward. I have a set of Currie Rock Jock D60's on my jeep. I beat the crap out of it on the rocks and have never broken anything.
    Bentrodder and jberry813[OP] like this.
  5. Nov 26, 2018 at 2:17 PM
    #85
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    Just read the whole thread. Definitely a good solution the our rear diff problem, although also not cheap.
    I"m wondering if the 3rd gen 8.75 rear diff would be another option for those looking to upgrade while spending a little less money and a more direct bolt in. I'm guessing it would be a direct, or pretty close to direct, swap. Next time I blow a ring and pinion I might find out
  6. Nov 26, 2018 at 2:46 PM
    #86
    ThomasMore66
    Dallas/Fort Worth & Durango
  7. Nov 28, 2018 at 10:26 AM
    #87
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Anderson likes this.
  8. Nov 28, 2018 at 10:43 AM
    #88
    ThomasMore66
    But you could be an active participant. I'm already thinking that 9" would be awesome in my truck. Just about the time I think I'm done, somebody charts a new course and I have to have it!
    jberry813[QUOTED][OP] likes this.
  9. Nov 28, 2018 at 10:44 AM
    #89
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I apologize. Been camping.
    Anderson, tacomgee and Bentrodder like this.
  10. Dec 2, 2018 at 9:29 PM
    #90
    Pibbles99
    Pibbles99 One more cast
    Brian
    Southern NH
    21 OR dbl cab
    I didn’t read the whole write up, but how long did the whole shooting match take?
  11. Dec 1, 2020 at 5:37 PM
    #91
    RedFiveaz
    RedFiveaz Member
    2013 Tacoma Double Cab 4x4 6 Speed
    LT Front/Rear
    Sorry for the thread revival. I contacted Currie about their Ford 9in built specifically for Tacomas. They said they no longer build these and that I could order a custom Ford 9in from them, but it will have no Toyota parts on it.
    I'm doing long travel with trailing arms and eventually I might do an LS swap. I want to upgrade the axle if I'm going to all this trouble, but it seems I missed the boat with Currie. Does anyone else make a Ford 9in that solves the magnetic bearing speed sensor and ABS issues like Currie did previously? Or does anyone know what Currie was doing to solve those issues?
    Thanks guys!
  12. Dec 1, 2020 at 6:47 PM
    #92
    ZRTX
    ZRTX Well-Known Member
    Des Moines Iowa
    Look into this.
    https://www.justdifferentials.com/Ford-9-Rear-Axle-Housing-3rd-Member-Upgrade-p/nphtac-f9.htm
  13. Dec 1, 2020 at 7:22 PM
    #93
    RedFiveaz
    RedFiveaz Member
    LT Front/Rear
  14. Dec 2, 2020 at 4:24 AM
    #94
    Rockbaron1
    Rockbaron1 Well-Known Member
    Pat
    03 Tacoma
    everything
    Im using a land cruiser fzj80 rear axle with the 9.5" diff in my first gen. The offset hasnt been a problem and the ABS is plug and play. Also you should contact Diamond Axle if you want something custom using Toyota stuff.
    RedFiveaz[QUOTED] likes this.
  15. Dec 2, 2020 at 6:09 AM
    #95
    RedFiveaz
    RedFiveaz Member
    LT Front/Rear
    I deleted the ABS on my (recently sold) FZJ80. I wish you all the luck with that system! But thank you so much for the lead, I'm going to reach out to Diamond right now. Looks like they can do exactly what I need! I'll report back. Thank you!!
  16. Dec 2, 2020 at 8:02 AM
    #96
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I don’t know much about axles and how it compares to the one in this thread, but here’s a beefy replacement.
    https://eastcoastgearsupply.com/i-23837729-2005-2015-toyota-tacoma-dana-60-bolt-in-rear-axle.html
  17. Dec 2, 2020 at 8:59 AM
    #97
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    If you deleted the abs then why not just build a regular 9 in with 60 ends that are 6x5.5? Trail gear, spidertrax, fourwheelsupply, currie and lots more all offer 6x5.5 unit bearing hubs and brakes and solid axle industry and nitro gear offer 6x5.5 hubs meant for a spindle.
    jberry813[OP] likes this.
  18. Dec 2, 2020 at 10:42 AM
    #98
    Muddinfun
    Muddinfun Well-Known Member
    Man, that Currie setup is sweet. No way in Hell you'll ever break that.
    It's too bad that Currie quit making this, but here's my thoughts on how to do this on the "cheap". Still going to be slightly expensive, but nowhere near what the Currie setup probably sold for.
    Get a 1978ish F150 rear axle. Go to a place that narrows axle housings. Have them cut off the Toyota ends off your stock axle and weld them on the 9" at what ever width you want. They may have to make Toyota pucks for their alignment bar. Then go to a place that makes custom chromoly axle shafts and have them make Tacoma axles with Ford 9" splines. The 1978ish F150 is 31 spline. Although you could go to 35 spline, there is no way any motor that will fit in a Tacoma is going to shear a 31 spline chromoly axle shaft.
  19. Dec 2, 2020 at 10:47 AM
    #99
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Good luck finding that f150 axle. Every place out west has been picked clean for years since desert racing took off.
  20. Dec 2, 2020 at 10:51 AM
    #100
    Muddinfun
    I've got a couple of extras. LOL. Guess I'll hang onto them.
    EdgemanVA likes this.
