Installing a diff drop
Discussion in 'Suspension' started by JDMcompliant, Jul 20, 2010.
  1. Jul 20, 2010 at 1:57 PM
    JDMcompliant
    JDMcompliant [OP] Professional Amateur
    Joe
    San Diego
    2010 Tacoma 4x4 4.0L V6
    Hey all,
    I'm thinking about installing a diff drop on my truck. Hard turns cause a loud POP from the front wheels and it's very concerning. Is this a difficult install?
  2. Jul 20, 2010 at 1:59 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Don't bother. It does virtually nothing.
    If you're hearing a pop then your CVs might already be shot. How much lift are you running?
  3. Jul 20, 2010 at 2:00 PM
    JDMcompliant
    Joe
    San Diego
    dammit. haha.
    installers set my front coils at 3.5".
  4. Jul 20, 2010 at 2:01 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    ^x2 on the pop... since you are running more than 3" of lift I suspect your cvs are going if you routinely hear a pop
  5. Jul 20, 2010 at 2:02 PM
    JDMcompliant
    Joe
    San Diego
    damn...it only happens when my wheel is turned completely one way or the other. any way i can tell if they're shot?
  6. Jul 20, 2010 at 2:13 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    reach under the truck and grab the axle,try to move it,there shouldnt be any play in it
  7. Jul 20, 2010 at 2:26 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2010 FJC
    55w HIDs, 16" Countersteer Offroads, Yokahama All Terrains, Demello Sliders
    x2 on diff drops being worthless. However, if you insist on giving away the money, please send it to me. :p
    Lower your Coilovers and replace the CVs if needed. IIRC, angles are best at ~ 2.5" of lift.
  8. Jul 20, 2010 at 2:30 PM
    JasoTaco
    JasoTaco Well-Known Member
    Salt Lake City, Utah
    09 Tacoma TRD Off Road
    ToyTec Ultimate 3" Lift -TSB Rear springs - TRD Cold Air Intake - TRD Skid Plate - Total Chaos Upper Control Arms - 2 Hella Rallye 4000 lights (130W Bulbs) - Clear Bra - Under Coat - Bed extener - Toyota Bed Mat - Weathertech floor mats - Tailgate hose clamp & washer mod - PIAA Fog Lights - ScanGauge II - Beefed Sliders - Differential Breather Mod - Heated Seats - All-Pro Bumper - Warn M8000 Winch with wireless controls - Boztec Diff Skid - ATO skids
    Why would a diff drop be worthless?
  9. Jul 20, 2010 at 2:32 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    agreed
  10. Jul 20, 2010 at 2:32 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    right, but does it always happen when you turn in this manner?
  11. Jul 20, 2010 at 2:32 PM
    JDMcompliant
    Joe
    San Diego
    i stepped out of the office to try it, and it's weird...i wouldn't call it "play," because i couldn't feel any movement, but there was a sound i could identify whenever i rocked it back and forth. i don't know if this is normal or not.
    haha, the DD was only $30 from toytec so i thought it would be an easy fix. looks like i'm gonna have to lower my coils? :(
  12. Jul 20, 2010 at 2:33 PM
    JDMcompliant
    Joe
    San Diego
    yep, always. like, i know not to turn that much when i pull out of a spot. i turn less, back up, then complete the turn.
  13. Jul 20, 2010 at 2:34 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    i dont think diff drops are worthless at all, they are not a hard install and they help your CV angles
  14. Jul 20, 2010 at 2:35 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    yeah it shouldn't make any sounds...and probably shouldnt move at all, maybe they are about to give out
  15. Jul 20, 2010 at 2:45 PM
    JDMcompliant
    Joe
    San Diego
    yeah, that's what i was thinking...so someone help me out here:
    1. I have a 3.5" lift in front.
    2. The recommended lift for the angle for the CV joint is 2.5"
    3. The diff drop will lower the differential by 1"
    4. 3.5" - 1" = 2.5" (the recommended lift height for proper angle)
    Am i missing something?
  16. Jul 20, 2010 at 2:46 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    Sounds like the diff drop would help you. Bet the CVs have too much of an angle on them.
  17. Jul 20, 2010 at 2:47 PM
    JasoTaco
    X2
    I put the ToyTec DD on mine.
  18. Jul 20, 2010 at 2:49 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    well give it a try diff drops are cheap and relatively easy install
  19. Jul 20, 2010 at 2:57 PM
    JDMcompliant
    Joe
    San Diego
    yeah, i figure i'd give it a shot...i mean it's less than a tank of gas :p
  20. Jul 21, 2010 at 7:07 AM
    mjp2
    NJ
    Differential drops work on the pre-2005 Tacomas because they actually lower the differential.
    The front diff on the 05+ trucks is mounted completely differently. Installing a diff drop on the new trucks only pivots the differential, increasing the front drivesahaft u-joint angles. More stress on the front driveshaft and many people have reported vibrations from it after installing a differential drop on their trucks.
    A 1" spacer will lower the differential at the spot where the inner CVs insert by less than 1/2". A larger spacer would be needed to drop a full inch, but then you're dealing with even more stress on that front driveshaft and you start running the risk of hooking your diff on something when wheeling as the front mounts are now sticking way below the truck.
    Pick and choose your battles. I'd rather lower the truck an inch than deal with the issues introduced by the drop spacers.
