Installing a garage door opener
Discussion in 'Garage / Workshop' started by Brian007Taco, Apr 16, 2013.
  1. Apr 16, 2013 at 9:59 AM
    Brian007Taco
    Brian007Taco [OP] 007Taco
    Don't ask!
    Tempe, Arizona
    12 OR 4x4 dcsb
    12 OR 4x4 dcsb 265/75/16 KO2's wrapped on MB352's. Toytec CO's with 5100's front and back, 1/2" block and aal. Derped Emblems. Tree Smashed Taco 06 OR AC Prerunner! OME 885 with 5100's in front, TSB and AAL with 5125's in back. 30" light bar in the valance.
    Have you installed a garage door opener? If so, on a scale of easy to hard, what would you rate it.
    I work for a packaging design company are we are redesigning the packaging for Chamberlain, Liftmaster and Craftsman. My company is giving away the garage door openers to all of it's employees. I am getting one and was going to install it at my house.
    Should I hire someone to install it?
  2. Apr 16, 2013 at 10:05 AM
    gearcruncher
    Canadain bumper technician
    I have installed a few .
    All depends on your level of carpentry/ mechanical and electrical capability / reading and following instructions that come with the opener .
    Open the box and read through the instructions to see if you are comfortable with the job .
    Under ideal conditions , a contractor shouldnt charge more than 2 or 3 hours to install the opener
  3. Apr 16, 2013 at 10:16 AM
    oldstick
    oldstick Middle Age Member
    GA
    Fairly easy, the instructions are usually very thorough. Helps if there is already an electrical outlet for it nearby in the ceiling though.
  4. Apr 16, 2013 at 11:11 AM
    Brian007Taco
    Don't ask!
    Tempe, Arizona
    12 OR 4x4 dcsb
    Thanks!
    Yes it does. The ceiling has several areas with overheard outlets.
  5. Apr 17, 2013 at 10:15 AM
    oldstick
    GA
    That's good, then it's mostly a matter of locating the ceiling joists to bolt the mounting brackets into. A cheap electronic stud finder is very handy if you don't have one already. Assembly of the rest of the unit is fairly straightforward if you follow the intructions.
  6. Apr 17, 2013 at 10:28 AM
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    Took me less then an hour to replace my moms last year. Rails mounts and all. I had my door replaced less then a year ago and it took about two hours with door and opener but it was done by a pro.
  7. Apr 17, 2013 at 10:41 AM
    Brian007Taco
    Don't ask!
    Tempe, Arizona
    12 OR 4x4 dcsb
    Good to know.
    I found out yesterday as work was handing them out that the one I got is in french. The unit is sold in Canada. Hopefully it will work when I plug it in. If it doesn't, I can switch it out for another one.
  8. Apr 17, 2013 at 3:49 PM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    2011 Timberland Mica 4X4
    Leather seats, WeatherTech's, Access LiteRider tonneau cover, extra D-rings in bed & tailgate. Pelley lightbar with Hella 700FF's. Temp./compass O/H console.
    Well then you're good to go. If French speaking people can install them...:D
  9. Apr 17, 2013 at 3:51 PM
    Brian007Taco
    Don't ask!
    Tempe, Arizona
    12 OR 4x4 dcsb
