Installing a LED Horn Toggle Switch
Discussion in 'Lighting' started by Old_Greg_2005, Jan 5, 2018.
  1. Jan 5, 2018 at 12:11 PM
    Old_Greg_2005
    Old_Greg_2005 [OP] New Member
    2005 Base Unit Tacoma
    I have a oogah horn that I've wanted to mount up for a while now.
    Purchased this
    https://www.amazon.com/SupportTM-Bu...id=1515182936&sr=8-6&keywords=led+horn+switch
    Im curious if anyone else has gotten one, or something like it, and how you wired up the LED.
    To your dash lights, or just ran a power and ground off the fuse panel like from the radio or some such so the light isnt constantly on.
    any help appreciated
  2. Jan 14, 2018 at 8:52 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I used an add-a-fuse on the tail light fuse behind the coin tray for the positive and grounded the negative under the dash. So the dash dimmer doesn't affect the add on switch, but the dimmer was harder to get to and it hasn't bothered me, usually don't dim the dash lights anyway.
  3. Jan 15, 2018 at 7:58 AM
    Old_Greg_2005
    Thanks, that is what I was looking for!
