Installing a new radio
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BryanM1234, Jan 22, 2020.
  1. Jan 22, 2020 at 4:09 AM
    BryanM1234
    BryanM1234 [OP] Member
    Bryan
    2017 Toyota tacoma double cab 4 cylinder
    Just bought a new radio for my truck.Seemed like there was a lot of additional items I had to purchase to make it work.Was wondering,is there a lot of items that they said that I needed that I really dont???FYI I bought the new radio from Crutchfield.I have heard good things about them.Thanks Bryan
  2. Jan 22, 2020 at 4:42 AM
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    Welcome to TW Bryan. Often the additional items are to avoid having to splice wires and provide the easiest install "experience". If you post what you were advised to order we might be able to help further. I highly recommend Crutchfield and use them for every upgrade I do to my own rigs. Their instructions should clearly state what is used where and yes at times there will be left over connections or cables for different model/trim setups. Good luck with your install!
    deadpocketss likes this.
  3. Jan 22, 2020 at 5:15 AM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    I have used crutchfield for other vehicles and they always tell you what you need. In this case it is most likely a harness to retain steering wheel controls, an adapter harness for Toyota to the radio to make it easier, and depending on what radio you are getting probably an install kit for it to mount up to.
    I had a Dodge dakota that the factory radio was an odd ball 1.5 din and had these little ears on each side cut out for the controls. I looked all over and could not find anything that would work for me. Crutchfield had everything I needed, even though it was some odd stuff. I would trust them again.
  4. Jan 22, 2020 at 5:48 AM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    Crutchfield knows what they're doing if you buy the harness and everything from them they'll put the wires together so it's literally plug and play. You might still have to program the maestro rr unit. But it'll be easy
  5. Jan 22, 2020 at 6:01 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    Some specifics would be awesome.
    What radio, what addon things are you buying etc etc etc
  6. Jan 22, 2020 at 6:12 AM
    TacOffRoad11
    TacOffRoad11 Well-Known Member
    Josh
    Georgetown, KY
    '18 F150 XLT
    As someone who installs radios on the side, Crutchfield is spot on with what they suggest. Most adaptors are for being able to keep “factory” things like steering wheel controls and others.
    BryanM1234[OP] and daddy_o like this.
  7. Jan 22, 2020 at 6:23 AM
    Clearwater Bill
    Billy
    Largo Florida
    Wondering why folks don't ask questions like this pre-purchase?
    Seems it would make things much simpler...........
  8. Jan 22, 2020 at 8:25 AM
    Riotfunk
    Riotfunk Well-Known Member
    Taco TRD off road
    Head unit is just plug and play with the adapters, maestro, etc
  9. Jan 22, 2020 at 2:33 PM
    BryanM1234
    Bryan
  10. Jan 22, 2020 at 2:34 PM
    BryanM1234
    Bryan
    Thanks to all that responded.Its been decades since I installed one myself yet alone bought one.Thanks again.
