Installing a subwoofer and need a little help.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AMartin, May 24, 2017.
  1. May 24, 2017 at 5:39 PM
    AMartin
    AMartin [OP] Well-Known Member
    Andre
    New Brunswick
    2009 TRD sport DCLB
    3" Bilstain lift, Anytime Fog, Skid Plate, Procomp 7036, Cooper STmaxx, Heated Seats, Interior Plugs.
    So I bought a Pioneer TS-WX120A, one of those little compact subwoofers. This is my first time installing something audio related. Hooking it up to my stock head unit, I have everything installed except for one wire that Im not sure where to connect. According to the instructions it needs only 2A? Its to power the remote to adjust the bass and gain. I was thinking of doing a add a fuse to the fuse panel behind the little compartment on the driver side.
    If someone could tell me where to hook this up it would be great.
    I have a TRD sport with JBL audio if it makes a difference.Screen Shot 2017-05-24 at 9.38.35 PM.jpg
    Posting a photo, will save a lot of explaining lol.
  2. May 24, 2017 at 6:59 PM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    This fuse doesn't just power the remote. It triggers an internal relay to power the amplifier, switching on the 10A circuit.
    You have several options:
    1. You could look at the wiring diagram, there is a power antennae feed that could suffice, but you should make sure it doesn't turn off during CD/Aux play.
    2. Instead wire the power from your fuse box, use an "Add A Fuse" that you can purchase from any part store. This will turn the amp on with the ignition power.
    ?. Optionally you can add a switch to this circuit so that you can immediately cut off the subwoofer but leave the stereo alone. (for when your kid borrows the car and plans to blow up yet another one)
    :thumbsup:
    Lord Helmet likes this.
  3. May 24, 2017 at 7:03 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    I used the 7.5A acc slot and an add-a-fuse
  4. May 25, 2017 at 3:19 AM
    AMartin
    Andre
    New Brunswick
    2009 TRD sport DCLB
    Awesome, thanks for the info guys!!
  5. Feb 12, 2019 at 12:02 PM
    Roddy13
    Roddy13 Well-Known Member
    how did this end up sounding and where did you locate it?
  6. Mar 18, 2019 at 7:35 AM
    AMartin
    Andre
    New Brunswick
    2009 TRD sport DCLB
    I like it, gives it good base, better sounds quality in general. I have a double cap, I mounted it under the middle head reste.
