Installing a Truck Box (Info and Pics needed)
Discussion in '1st Gen. Tacomas (1995-2004)' started by vapovick, Sep 2, 2010.
  1. Sep 2, 2010 at 6:48 AM
    vapovick
    vapovick [OP] Active Member
    1999 Toyota Tacoma 4x4
    So I finally scored a great deal on a truck box. Box fits with about 10" clearance on each side. Should I just drill thru and bolt? Any recommendations would be great, pics even better.
    Thanks,
  2. Sep 2, 2010 at 2:25 PM
    vapovick
    bump...
  3. Sep 2, 2010 at 3:53 PM
    davestaco
    davestaco TW's number one gear whore
    David
    Schofield Barracks
    00' tacoma xtra cab trd v6 4x4
    yep just drill through and slap a bolt through there
  4. Sep 3, 2010 at 11:57 AM
    vapovick
    just thru the bed right, not the frame? The box didnt come with hardware, so i will have to gather that. I was thinking hex thru the bottom and a couple of nuts in the box, plus washers... I have a bed liner as well, so I guess I will just seal it with a little silicon.
  5. Sep 3, 2010 at 4:51 PM
    davestaco
    David
    Schofield Barracks
    ya ill take pics of what i used to have in my old f150 when i get the chance but if you open the tool box and drill through the box into the upper rim of your bed you will be able to slide a bolt in there(dont forget the washers!) and but a bolt on the end of it between your cab and your bed. i hope i could help explaning that haha
  6. Sep 4, 2010 at 2:23 AM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    I know this should go with out saying, but please be careful where you drill. There are brake and fuel lines directly under the bed, as well as the fuel tank. Also, you may not be able to access where you drill if you dont look first.
    Also, I dont know what type of truck box you have (chest vs side open), but also, please make sure the top will open before mounting it. That would really suck to have to drill more holes than needed.
  7. Sep 4, 2010 at 7:53 AM
    davestaco
    David
    Schofield Barracks
    x2....i wouldnt even drill into the bottom of the bed for safty reasons....
  8. Sep 4, 2010 at 8:02 AM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    x3 I'd drill in the rails but not the bed.
  9. Sep 4, 2010 at 8:19 AM
    snoope
    snoope Well-Known Member
    Ft.myers,FL
    2003 Lexus ES300/2004 Lexus 330 AWD
    DO NOT go cheap on your hardware......and as stated be VERY CAREFUL drilling....
    If you have 10" clearance on each side ,your box must be around 3' wide correct...be VERY anal about where it centers ,if any of the FACTORY bed fasteners are nearby you will have to adjust your hole patterns....
    More work but would you be up to putting 2 pieces of angle down to build a mount.....this way you can pick and choose where the holes could be and actually take it a step further and weld tabs in to secure the box at 4 angles...side to side and back & forth...
    Whatever you decide PLEASE take your time and try MANY different ideas before drilling....proper set up will save you HOURS of frustration...
    Good luck.. and pix when complete..;)
  10. Sep 4, 2010 at 8:23 PM
    vapovick
    Thanks all! I plan on tackling this on Monday, so I will take some pics and reply.
  11. Sep 4, 2010 at 8:51 PM
    davestaco
    David
    Schofield Barracks
    cool have a safe and exciting labor day!
