Installing AC Outlet in a non-sport model
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Djarmpit, May 11, 2013.
  1. May 11, 2013 at 10:15 PM
    Djarmpit
    Djarmpit [OP] Well-Known Member
    So I didn't buy the model with the power outlet installed in the back,
    But I was wondering if it was possible to install it as an aftermarket mod? Or is it possible to buy it from Toyota and them install it?
  2. May 12, 2013 at 1:30 AM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    Install an aftermarket inverter. The Bed one only runs up to 400W, not much.
    Pepboys sells inverters that have remote switched, which you can mount in the switch blanks. Keep the inverter either under a seat, or behind the rear seats and run wiring to the batter/outlets you can mount in the cab or bed.
    Here's one of the inverters
    http://www.pepboys.com/product/deta...onics/mobile_power/power_converters_inverters
    I'd search for AC outlets in center console, there are lots of guys here that have mounted regular outlets you would see in your home, in the bed and the center console.
