Installing Access lite rider cover
Discussion in '2nd Gen. Tacomas (2005-2015)' started by erm626, Oct 2, 2010.
  1. Oct 2, 2010 at 8:32 AM
    erm626
    erm626 [OP] Well-Known Member
    Ed
    Norfolk, Virginia
    Tacoma 4x4 SR5
    Access Tonneau Cover, EGR window Visors,Trail FX Step Bars
    It's my understanding the the torex # 30 bolts in rail, need to be removed for the new hardware. I tried loosing the bolts got all but two and of course stripped the heads. What now ?? Any simple Idears??
    Ed
  2. Oct 2, 2010 at 8:37 AM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
  3. Oct 2, 2010 at 8:49 AM
    erm626
    Ed
    Norfolk, Virginia
    Tacoma 4x4 SR5
    I have found many other sites on this subject I now have some opitions now
  4. Oct 5, 2010 at 8:42 AM
    WV4x4
    WV4x4 Member
    probably to late but I would say you could start with a left hand drill bit if that doesn't bring it out you already have a hole to use with an easy out.Good luck.
  5. Oct 6, 2010 at 2:48 AM
    erm626
    Ed
    Norfolk, Virginia
    Tacoma 4x4 SR5
    FYI
    easy out stripped the head even more....solf alummium.. I slotted what was left to the head and use a small chisel, and tap it with a hammer counter clockwise and both of them came out.. But thanks for the input!!
  6. Oct 6, 2010 at 6:51 AM
    WV4x4
    WV4x4 Member
    glad you got 'em out. there's always more than one way
  7. Oct 6, 2010 at 8:05 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Same thing happened to me. Some of the bolts were easy to break free with just a ratchet, others were completely over-torqued and I couldn't break the loose with a breaker bar. Inevitably I stripped 3 of them out pretty bad...so I drilled the heads off, and turned them out with pliers.
  8. Oct 7, 2010 at 2:59 AM
    erm626
    Ed
    Norfolk, Virginia
    Tacoma 4x4 SR5
    Install the Access lite rider last night with the help of my wife holding the rails. You certainly need a extra hand in the install. It went together without a hitch and looks great...
