Installing an oil pan heater on 2024 Off Road Tacoma
Discussion in 'New Members' started by SleddogJ, Oct 13, 2024.
  1. Oct 13, 2024 at 3:55 PM
    SleddogJ
    SleddogJ [OP] New Member
    Hello! I live in interior Alaska and trying to save money by winterizing my new 2024 Tacoma myself. I have the heater pad to put on the oil pan but just discovered there is a black plastic protective body around the oil pan. Anyone know if it's okay to still put on a silicone hot pad with that black plastic protective body on it? Thanks for any advice.
    buckhuntin-tacoma likes this.
  2. Oct 13, 2024 at 4:04 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    The heat pad needs to be in direct contact with the metal oil pan.
  3. Oct 13, 2024 at 4:15 PM
    SleddogJ
    Thanks crazysccrmd. I might not have been clear with my original post. I understand that the pad needs to be in direct contact with the metal oil pan. I'm checking to make sure that once the pad is installed on the metal pan and then covered up with that plastic shield that it won't be in danger of melting the plastic shield. Thank you
    crazysccrmd likes this.
  4. Oct 13, 2024 at 6:32 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    SleddogJ[OP] likes this.
  5. Oct 13, 2024 at 10:13 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    I’d leave the plastic off. If you can’t for some reason I’d either not install a pan heater or try to find the style that replaces your drain plug with a heater insert.
  6. Oct 13, 2024 at 10:18 PM
    SleddogJ
    Crazysccrmd- that's what I ended up doing. With further thought I realized this plastic covering is most likely on there because it's the off road trim. More protection for off roading. I don't plan to off road. My older 2010 tacoma was much simpler! Have a good night. I appreciate your advice.
