Installing an oil pan heater on new 2024 Tacoma Off Road
Discussion in '4th Gen. Tacomas (2024+)' started by SleddogJ, Oct 13, 2024.
  1. Oct 13, 2024 at 4:31 PM
    SleddogJ
    SleddogJ [OP] New Member
    I went to install an oil pan heater on my new 2024 and discovered it has a black plastic insulated protective covering on the oil pan. Wondering if it's fine to put the heater pad on the metal pan and then cover it with this black plastic insulated cover. Basically want to make sure I won't be in danger of melting the insulated plastic. Thanks for any advice
  2. Oct 13, 2024 at 7:30 PM
    Vitamins
    Vitamins Well-Known Member
    2024 TRD OR
    How cold does the tunda hellscape you live in get? I've been -30F and been okay with a block heater. It wasn't persistently cold at that temp though. Just a few mornings. I know it's common further north than where I lived to go block, oil, and battery heater. I've also seen guys leave diesels running 24/7 in the extreme cold.
  3. Oct 13, 2024 at 7:33 PM
    Bishop84
    Bishop84 Well-Known Member
    Absolutely not. Pan heaters have started a lot of fires. At the very least remove the plastic cover. But you're best off just installing the block heater and being done with it.
    Modern engines that use 0W20 like tacoma start just fine in -40 as long as the block heater is plugged in, maybe get a battery warmer.
    shakerhood and Stevie17 like this.
  4. Oct 13, 2024 at 7:42 PM
    JB_TN
    JB_TN Well-Known Member
    JB
    Tennessee
    2024 Bronze Oxide TRD OR
    OPs user name checks out for sure....
  5. Oct 13, 2024 at 9:14 PM
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    I keep waiting for a video that. I've looked and can't find the hole.
  6. Oct 13, 2024 at 9:16 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    To be quoted out of context later.
    Stevie17, SR-71A and crazysccrmd like this.
  7. Oct 13, 2024 at 9:28 PM
    Bishop84
    It's best to see through the drivers fender with the rear apron removed.
    Stevie17 likes this.
  8. Oct 13, 2024 at 9:37 PM
    Sagebrush
    Gens 1, 2, 3, and 4
    Thanks. I'll take a gander at it.
  9. Oct 13, 2024 at 10:06 PM
    islandhiker
    islandhiker Well-Known Member
    Calgary, AB
    2021 TRD Off Road AC
    Oil pan heaters & battery blankets were standard on alot of vehicles when I lived near the arctic ocean. But it would be -35/40c for weeks on end.
  10. Oct 13, 2024 at 10:14 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    He lives in interior Alaska where -40° is not uncommon. Everyone runs oil pan heaters and it makes a huge difference in start up. Yea my trucks have always started at those temps when not able to be plugged in but they run much smoother if things are slightly warmed.
  11. Oct 14, 2024 at 5:33 AM
    Vitamins
    2024 TRD OR
    I always hated that sound when I opened the door in the extreme cold. The door would make a screaming sound as it opened. Then when starting the car, all the lights are dim, the LCDs move really slow, it just goes oom oom oom and then finally catches.
  12. Oct 14, 2024 at 7:14 AM
    Bishop84
    I'm aware, we see -40 (in bursts) here as well but we also see numerous fires. I saw pan heaters fall off and burn cars/houses to the ground.
    Toyota had to rework all their block heaters simply because of fires caused by the cords.
    All of my cars start just fine when left in -40 for days if the oem block heater is plugged in, but I always run 0W oil.
