Installing AP LT this weekend...have a question
Discussion in 'Long Travel Suspension' started by 09blacktaco, Feb 1, 2012.
  1. Feb 12, 2012 at 5:34 PM
    09blacktaco
    09blacktaco [OP] Well-Known Member
    The Rockies
    09 DC 4x4 TRD OR
    No luck getting anyone to press those stubs out of the star. Going to the napa machine shop tomorrow, I'm sure they will get it. Looks like I'm having the same trouble as mark. :(
    I did get the new brake lines installed and bled the brakes today.
    I'll put some pics up when I get home.
  2. Feb 12, 2012 at 5:41 PM
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    Take it anywhere with a lathe. They can chuck it up by the piece of shaft left exposed (cut side) and gouge out the shaft material up to the c-clip from the back side. Works everytime. Just make sure they dont damge the splines on the inside of the "star" or "cross" (inner piece of the cv joint once disassembled).
    I doubt they will get it pressed out.
  3. Feb 13, 2012 at 9:10 AM
    Zlagger
    Zlagger Well-Known Member
    Rich
    Santa Cruz
    2010 DBCab TRD Long Bed
    AllPro LT front -w- Fox 2.5 COs, rear AllPro 3" springs -w- King 2.0 shocks
    Thanks for posting this thread. Keep it up, I'll be doing this exact install in a few days.
  4. Feb 13, 2012 at 1:53 PM
    Anteupp
    Anteupp Mega Member
    Andrew
    South East Wisconsin
    Total Chaos Long Travel 4x4, Fox Coilovers, DMZ spring under, 16" king tripple bypasses, Garage built bedcage/bumper, full cage coming soon...
    it took a 50 ton press to get the snap ring on my axles to bust.
  5. Feb 14, 2012 at 5:20 AM
    09blacktaco
    The Rockies
    09 DC 4x4 TRD OR
    Napa was able to press out the axle studs with 10 tons of force. It actually sheared off the snap ring, so theres no way I could have gotten it out without an HD press.
    Anyway I froze the new axle shafts for 2 days before I re installed and they slipped right in without too much of a fuss. Couple of whacks with a 10lb sledge and I was done.
    After that everything went together quick.
    Do you guys knoiw how I should install the steering extension? I was wondering if I needed to keep the lock nut on there or ditch it... I can't tell by looking at it and the instructions dont help. I'll call AP this morning if now one knows whats up.
    Is this right?
  6. Feb 14, 2012 at 11:43 AM
    09blacktaco
    The Rockies
    09 DC 4x4 TRD OR
    I called AP this morning and spoke with Kurtis about the fact that I cant fit the spacers between the inner bushings of my UCA and LCA. He suspects they may have sent me FJ control arms, he going to measure a couple of sets and call me back. :rolleyes:
    If you look at the pic you can see how close my LCA bushing are to the frame mount. Almost flush with the mount. I used the two supplied black washer on the outside of the bushings to fill the huge gap on both mounting points. :frusty:
    On the UCA I had to use some smaller grade 8 washers, which i had to presuade into place with a bfh.
    Something definitely isn't right. What a pain in the ass!
  7. Feb 14, 2012 at 12:02 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Wow....that sucks ass. Sounds like some parts are about to be overnighted to you
  8. Feb 14, 2012 at 5:12 PM
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    My LCA's are mounted the exact same way. I could only get them in with the two washers on one side......I figured I had mangled my LCS mounts a bit...wait so tell me I dont have the wrong friggin arms...
    And to the OP:
    Where did you get new clips for the birf end of the axle?
  9. Feb 14, 2012 at 5:27 PM
    09blacktaco
    The Rockies
    09 DC 4x4 TRD OR
    AP stepped up and I got new uppers and lowers on the way, so we shall see if they are different on Thursday. Kurtis at AP said that I should be able to get the washers on both sides. Ill post pics.
    Hole Ring P/N: 43425-04040
    Fit in the AP axle perfect, my factory one looked smaller in diameter.
  10. Feb 14, 2012 at 5:37 PM
    MonkeyProof
    SoCal- SGV
    :facepalm:
    edit: maybe AllPro should paint the FJC arms a different color..so they don't get confused with one another:crazy:
  11. Feb 14, 2012 at 6:06 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    Or just don't be so silly and take 2 seconds of their time to look at the thread.
    Edit im talking about steering extenders lol derp
    But still they can take a few seconds to look at the arms, aren't they stocked in a location with different part numbers and shit? I don't imagine they are just piled into a giant box
  12. Feb 14, 2012 at 6:14 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Jośe
    Woodlandland hills , CA
    Taco
    Lift- king 2.5 with light racing uppers,tc coil bucket gusset, 4 in spindles,timbern bumps all around ,wheelers 3 addaleaf, ato shackle flip kit with 6 inch HD shackles. Armor- tire gate, custom tube bumper, kr fab rear bumper,trail gear wiy 78 in sliders Performance-intake manifold spacer, hps silicone hoses Random stuff- kenwood head unit,b&m t shifter, hood bug deflector, rear dust lights with custom bed bar and hi lift mount.
    Op truck look sick
  13. Feb 14, 2012 at 6:32 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Calgary
    2006 Campster Mobile
    My truck is MAGIC
    this thread is great. hopefully will be installing AP LT on my DCLB soon!
  14. Feb 14, 2012 at 7:27 PM
    singlefin
    singlefin Well-Known Member
    Portland, OR
    Syncro
    Devil in the details.
    Glad to see you got your axles sorted. Frustrating that your weekend project pushed into mid week. Hope your stuff shows up on time and you can get a good shake down run over the weekend.
  15. Feb 15, 2012 at 7:41 AM
    #35
    09blacktaco
    The Rockies
    09 DC 4x4 TRD OR
    no doubt the axles were the hardest part, but now that I've done the whole process, i realize that it really wasn't that bad. I can do it again in half the time. It was a great learning experience not to mention i also learned some new curse words. :D
    I'm really hoping that the new arms fit properly, if they don't, I'll improvise I guess, not much choice at this point with the stock axles cut. I'm looking forward to getting it drive able again. There's not many places around here to really use the long travel, but i'm sure I'll find some power-line trails to do a little shakedown. :broccoli:
    We are moving to Colorado at the end of the year, so i'm sure this kit will pay off for me in the long run!
  16. Feb 15, 2012 at 1:09 PM
    #36
    focotacoma
    focotacoma Well-Known Member
    Fort Collins
    07 Speedway Blue 4x4 TRD off-road
    Im getting there......
    where a bouts?? nice truck btw
  17. Feb 16, 2012 at 5:08 AM
    #37
    09blacktaco
    The Rockies
    09 DC 4x4 TRD OR
    thanks :cheers:
    Going to rent in Vail for a year or so while we look/build a house. We really havent decided on Colorado or Washington state yet, but having friends in Vail makes it a good transition point for us.
  18. Feb 16, 2012 at 5:58 PM
    #38
    09blacktaco
    The Rockies
    09 DC 4x4 TRD OR
    I got the new arms today :D
    Got the new uppers put on and they fit perfect now. Def. had either the wrong arms or just a bad set.
    I'll get the rest on tomorrow. Hopefully the lowers are perfect too! :turtleride:
  19. Feb 16, 2012 at 9:00 PM
    #39
    ItsHerTruck
    ItsHerTruck The Primeministah
    Alex
    K-Town, Hawaii
    2010 Timber TRD Debadged
    Radflo coilover, dakar leaf pack, Light racing UCA,walker evens 9.5,ap ubolt flip,retro fits,wet O's,TRD catback,K&N intake,grill craft,allpro plate bumpers,warn m8000,safari snorkel,etc.
    Looking good..:D
  20. Feb 20, 2012 at 5:48 AM
    #40
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    Please take some measurements on the lowers, and the ones you remove as well, I am thinking I have the wrong lowers too :eek:
