Installing bike races over a tonneau cover
Discussion in '2nd Gen. Tacomas (2005-2015)' started by oncpa23, Nov 7, 2017.
  1. Nov 7, 2017 at 6:11 PM
    oncpa23
    oncpa23 [OP] Member
    Albuquerque, NM
    2014 DC TRD Off Road Pre Runner
    Hard tonneau cover added
    I tow a vintage 16 ft camper with my 2014 Tacoma and m looking into the feasibility of a bicycle rack that installs over the tonneau, possibly attached to the top edges of the truck bed.
  2. Nov 7, 2017 at 6:23 PM
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
  3. Nov 8, 2017 at 9:57 AM
    oncpa23
    oncpa23 [OP] Member
    Albuquerque, NM
    Thank you for the link, HawkShot99. I will look into this
  4. Nov 8, 2017 at 10:26 AM
    Pigpen
    Dan
    Northwest Montana
    You can use the drill through options from Yakima and Thule also. They only seem less expensive than some of the small operation options, they really arent - once you add up all the needed parts.
    Check out the side of the truck rack from @KB Voodoo as an out of the bed option.
  5. Nov 8, 2017 at 12:27 PM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
  6. Nov 8, 2017 at 12:54 PM
    HawkShot99
    Kingston, NY
    The drill through would only work if he had a 1 piece solid bed cover. Obviously no good on a soft cover, and if a hard folding cover, you will make it so it won't fold flat.
    oncpa23[OP] likes this.
  7. Nov 8, 2017 at 12:58 PM
    Pigpen
    Dan
    Northwest Montana
    Yep
  8. Nov 8, 2017 at 1:01 PM
    Pigpen
    Dan
    Northwest Montana
    He said "possibly" attaches to the sides of the truck bed. I took this to mean that attaching it to the tonneau was an option.
  9. Nov 8, 2017 at 1:46 PM
    HawkShot99
    Kingston, NY
    No worries. I was just pointing it out incase they didn't think of that potential problrm.
    oncpa23[OP] and Pigpen[QUOTED] like this.
  10. Nov 10, 2017 at 9:10 AM
    oncpa23
    oncpa23 [OP] Member
    Albuquerque, NM
    Thanks for the comments and thoughts. I will continue to research this idea. If I do find a workable solution, I will post pictures.
    Wishing all Veterans and Active/Guard/Reserve service members a Blessed Veterans Day.
