Installing Bilstein 5100's, OME Dakar Leaf, and OME 888 springs
Discussion in '3rd Gen. Tacomas (2016+)' started by SteenosMT, Aug 7, 2017.
  1. Aug 7, 2017 at 10:40 AM
    SteenosMT
    SteenosMT [OP] Well-Known Member
    Justin
    2016 Gray TRD Sport 4x4
    Bilstein 5100's, OME 888 Springs, Dakar Leaf, SPC UCA's, Spidertrax spacers.
    From what I've read if you leave the Bilstein 5100's on the bottom setting you should get about 2.75 out of the front and 2 inches from the rear. My question is.
    Does anyone have any pictures of their similar lift and if I wanted to get 3 inches out of the front and level it out in the rear does anyone have any recommendations? Thanks. Looking forward to getting this lift installed.
  2. Aug 7, 2017 at 10:42 AM
    JoeCOVA
    JoeCOVA IG @MightyJoeFlannel
    Joe
    Colorado Springs
    2017 DCSB TRD OR
    35" Trepadors w/ OMF Beadlocks, Kings, OBA, 5.29s etc
    smitty99 likes this.
  3. Aug 7, 2017 at 10:50 AM
    jsinnard
    jsinnard Crawl Control and longbed? I has it
    Virginia
    04 DCAB 4X4, 16 QS DCLB OR 4X4
    Smitty doesn't have 5100s, he has the Bilstein 6112 / 5160 combo.
    I have 5100s but on 885 springs and a 3 leaf Progressive AAL
    trdsupreme likes this.
  4. Aug 7, 2017 at 10:52 AM
    EatSleepTacos
    EatSleepTacos MOBTOWN OFFROAD AMBASSADOR
    Randy
    Chesapeake, VA
    4x4 2005 SR5 AC 6MT POOP Edition
    What exactly is the question here? Also do you really think you'll notice that 1/4" difference? Hint: The answer is no.
  5. Aug 7, 2017 at 10:52 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    I don't recommend 5100s because I have read too much feedback that they ride harsh/stiff but they will work for a budget lift and some people like them just fine. I do not know the specs on the 5100s so I recommend searching the Suspension Subforum to find answers to your questions and to get feedback on it. A ton of people run 5100s, they are probably the cheapest lift you can run without doing the 'taboo' "spacer lift" ...we won't go there...
    What makes you feel that you need or desire 3" of lift? Do you understand the impacts of costs and wear & tear on your vehicle that a 3" lift can bring vs. a 2" lift?
    I recommend a 2" lift maximum. Note that if you go over 2" you're going to need to buy new upper control arms if you want to be able to keep alignment numbers somewhere in the normal range and not have the truck drive like shit on the highway (darting around with extremely sensitive steering) because of your caster being out of whack. Also you're going to need to research getting the East Coast Gear Supply (ECGS) Bushing to replace your factory needle bearing which is a 2 to 3 hour job if you have the knowledge and tools otherwise a $300 to $400 job with parts and materials. You'll likely want to do this when you install the lift as if you do not, the truck starts vibrating like hell, you're going to need to tear the front driver side suspension all back off (or pay someone the labor) to install the ECGS Bushing to fix your vibes.
    See link in my sig below for 6112/5160 write up. A great option for these trucks and can be installed for maybe $2,000 parts & labor depending on labor quotes. You might save $500 or so if you do it yourself.
    Also see my sig below for a couple links explaining the Needle bearing/ECGS bushing replacement.
    harrycary likes this.
  6. Aug 7, 2017 at 10:58 AM
    SteenosMT
    Justin
    I just want to fit 285/70/17's
  7. Aug 7, 2017 at 10:59 AM
    smitty99
    Scottsdale
  8. Aug 7, 2017 at 11:00 AM
    SteenosMT
    Justin
  9. Aug 7, 2017 at 11:01 AM
    EatSleepTacos
    Randy
    Chesapeake, VA
  10. Aug 7, 2017 at 11:01 AM
    SteenosMT
    Justin
    So what are my options then?
  11. Aug 7, 2017 at 11:02 AM
    smitty99
    Scottsdale
    Do some reading in the suspension forum. These types of questions are asked every day and are beaten to death. Gotta use the search function man! You know it gets tough to answer these questions because they get asked so frequently and you have to type the SAME stuff over and over. That's really why using the search function is your best friend!:thumbsup:
  12. Aug 7, 2017 at 11:03 AM
    EatSleepTacos
    Randy
    Chesapeake, VA
  13. Aug 7, 2017 at 11:11 AM
    jsinnard
    Virginia
  14. Aug 7, 2017 at 11:14 AM
    SteenosMT
    Justin
    I've bought this lift. I'm not trying to fit 285's on stock setup.
  15. Aug 7, 2017 at 11:16 AM
    jsinnard
    Virginia
    Point being it's not about lift, it's about wheel and offset.
    SteenosMT [OP] and smitty99 like this.
  16. Aug 7, 2017 at 11:17 AM
    smitty99
    Scottsdale
    You have to be ready to CHOP and TRIM if you want to run 285s. end of story
  17. Aug 7, 2017 at 11:20 AM
    Edward R
    Edward R Edwood
    Ed
    Eugene
    2017 TRDORDCLB
    Leer 100xr shell. STMaxx 255/85. HeadStrong 5100 kit with 3leaf AAL. Clazzio matched seat covers.
    5100s, Headstrong 3AAL. Middle setting, got 3.4 all around. Has settled to 2 7/8 all around.FullSizeRender.jpg
  18. Aug 7, 2017 at 11:24 AM
    blkbelt42
    blkbelt42 Well-Known Member
    2016 Black AT DCSB 4x4 TRD Sport
    JL Audio C2690tx Speakers Alpine MRV-F300 JL Audio 10" Sub - Full length Ported Box Kicker Tweeters BFG KO2's 265/70/17 Tint N-Fab Bars Husky WB Mats AVS Visors Console Divider Tacoma Tonneau Cover ALL PRO 1.5" wheel spacers aFe CAI w/ Dry filter TRD Wheels Custom Remote Start TRD Pro Grille ECT always-on mod by MESO OV-Tuned - 1.03 ROAV Dash Cam 3" RC Lift
    this^^^ I did it and had to trim the front wheel well as well
    as some of the plastic (closest to the door).
  19. Aug 7, 2017 at 11:45 AM
    smitty99
    Scottsdale
    3 leaf Progressive AAL? It's good for 1.5". .....maybe 2" if you leave the Overload in from what i recall
  20. Aug 7, 2017 at 11:48 AM
    jsinnard
    Virginia
    Yep, left mine in and got 2 inches in the rear.
