Installing bilsteins today! Alignment question.
Discussion in 'Suspension' started by w4lter, Jul 10, 2010.
  1. Jul 10, 2010 at 12:16 PM
    w4lter
    w4lter [OP] Well-Known Member
    Omaha
    TRD Sport
    Westin bullguard, Steelcraft 3" Nerfbars, Bilstein 5100s all around -front set at 2.5", toytec 2" AAL, Wickedflow muffler, 265/70/17 Destination ATs.
    I'm finally installing My bilsteins/2"aal today. I know I have to get an alignment but tomorrow is Sunday and obviously most shops are closed. Will anything be damaged if I run down the street to the grocery store? What about highway across town to church? Is it just a handling issue? I'll be sure to post pics after.
  2. Jul 10, 2010 at 12:20 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    You will be fine, just get it done asap next week.
  3. Jul 10, 2010 at 1:24 PM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    I drove for6 days before I could get a alignment. I didn't want to go that long but there where no problems.
  4. Jul 10, 2010 at 1:26 PM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    Drove 2 weeks - not a problem at all... I don't even think I needed an alignment but had it done anyway. You should still get it done, but should be fine.
    Azbackcountry
  5. Jul 10, 2010 at 1:30 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    All you're really doing is scrubbing the tires a little bit... that's assuming it's even off a measurable amount. Driving it for a few days should pose no problem... I wouldn't set off on a cross-country trip before the alignment, though.
    I put 5100s up front on mine at 1.75" lift and took it in for an alignment. The tech came back in about 20 minutes later and asked if I had asked for an alignment or maybe something else since the wheels were almost exact on spec without adjustment.
  6. Jul 10, 2010 at 1:30 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    Handling, you'll be fine, just do it soon so you don't wear your tires uneven.
