Installing Block Heater on 02' Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jamer.d, Oct 25, 2017.
  1. Oct 25, 2017 at 12:28 PM
    Jamer.d
    Jamer.d [OP] New Member
    Hi all!
    I'm new to all this and am looking to install a engine block heater in my Tacoma. It's a 2002 V6 3.4L 5VZ-FE with a Manual Trans. Is there already an existing plug in the engine for a block heater or do i have to drain the anti freeze and what not?
    Also, if you know of anywhere that'll give you step by step instructions that would be much appreciated.
    Thanks!
  2. Oct 25, 2017 at 7:28 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    I'm either going to get one of those pads that stick on the oil pan, or a magnetic one. As seen on Amazon.
  3. Oct 25, 2017 at 9:30 PM
    kbeefy
    kbeefy Active Member
    Ken
    Bend, Oregon
    2002 DCSB 3.4 AT 4x4
    Warn 9.5XP, E-Locker, Bil 5100
    I don't know where you are, but I usually stick a pad heater onto the oil pan with HiTemp Silicone and call it good. Keeps the oil fluid and makes starts easy. I did this on many vehicles in Alaska and worked great. I'd rather wait a couple minutes for the coolant to heat up and have good oil flow than the opposite.
    DanK83 likes this.
  4. Jan 7, 2018 at 8:57 PM
    Arctic Taco
    Arctic Taco Firefly, Serenity Ed. -Arctic Taco, a slow build
    Denali Park, Alaska
    98 Tacoma Xtra Cab DLX, 85 Toyota LWB 4x4
    dents and missing bits, built in the Gravel garage, hillbilly trained mechanic…
    Oil pan heater is the simplest, and most functional, unless you are spending a winter in Fairbanks, then add a block heater as well.
  5. Jan 8, 2018 at 12:10 PM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
  6. Jan 8, 2018 at 12:17 PM
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
  7. Apr 27, 2018 at 10:50 AM
    ssoulssurfer
    ssoulssurfer Well-Known Member
    1998 Tacoma 4x4 SR5 TRD MANUAL TRANS 3.4L V6
    2.0 FOX COILOVERS FRONT, 5100 BILLSTEINS REARS
    Anybody actually installed something like this: https://trdparts4u.toyotaofdallas.com/scripts/prodView.asp?idproduct=-5504
    The heating pad sounds like a temporary solution for winter. I'm possibly moving to alaska in the next year and want to get my truck ready. 98 V6, and the actual location of freeze plug and method to install the heating element would be helpful!
  8. Jan 29, 2019 at 1:11 PM
    xcmtb83
    xcmtb83 Well-Known Member
    Iowa
    Did you ever get a block heater installed? I have found C0140-02134 to be the part number but my dealer is not able to source it so I may order one from a dealership in Ontario.
  9. Nov 11, 2020 at 12:41 AM
    TobiTaco
    TobiTaco New Member
    2002 Tacoma TRD
    Every mechanically minded person I’ve talked to in Fairbanks says it’s necessary to have a block heater as well as the oil pan heater, as well as a battery maintainer. Installed the latter two. Today I got a block heater from the Toyota dealer in Fairbanks for the same model, but after reading a lot of reviews I’m anxious about the freeze plug removal process. Did you ever install it? Which freeze plug? Any pointers?
