installing CB radio and coaxial cable - 3rd gen 4runner **Pictures**
Discussion in '4Runners' started by ramonortiz55, Jan 13, 2016.
  1. Jan 13, 2016 at 2:31 PM
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    I had my TWSS give me a Uniden PRO 520XL cb radio for my 4runner build.
    Thanks bud @adanfon
    The thing with these cb radios is that they fit PERFECTLY in the ashtray location on the 3rd gen 4runners.
    Give you a clean, stockish look:
    To be able to achieve this, I remove the radio/ac bezel on the 4runner:
    I pulled the ashtray out and remove these two screws:
    Test fitting the CB radio:
    Trimmed the end brackets off with a dremmel tool and test fitted again:
    Used two strips of velcro between the plastic prongs and the top of the radio.
    This holds the CB radio in place:
    Connected my PL59 connector:
    Dont forget to order pizza. If you dont, this MOD will NOT WORK:
    Looks like Arizona is winning:
    So now I proceed to run the coaxial wiring for the cb radio. I purchased this mount from a member on T4R.org. The mount installs in the back hatch:
    Picked up the firering coaxial cable, the 18 feet version:
    I ran the coaxial cable from the front of the 4runner towards the back:
    Under the carpet on the driver's side:
    Under the door floor plastic panel front and rear:
    I then removed the plastic paneling in the rear driver's side area by the seat:
    Removed the driver's side back cargo paneling:
    Ran it thru this yellow vent thing:
    Here it is!
    I then hid it from view by running it behind the bumper:
    Made sure to install the cable like this:
    bigmw likes this.
  2. Jan 13, 2016 at 2:37 PM
    ramonortiz55
    Ramon
    Texas
    stock
    Will post pictures of finished install later :D
  3. Jan 13, 2016 at 2:38 PM
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    looks good man!
  4. Jan 13, 2016 at 2:39 PM
    ramonortiz55
    Ramon
    Texas
    stock
    thanks Frank!
  5. Jan 13, 2016 at 2:40 PM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    also, I have the same radio. Love that thing! Still need to mount mine
  6. Jan 13, 2016 at 3:34 PM
    Husky Driver
    Husky Driver Kyna's chauffeur
    Kipp
    40°35'09.0"N 105°04'38.3"W
    2k T4R3 SR5 (Sport Edition Highlander SX) TRD
    Toytec Ultimate 3" lift susp w/ OME 891 rear coils, Bilstein 5100 shocks front & 5125 rear, ARB 'Roo Bar, Warn VR10k, 0.7, 2 & 11-meter 2 way radios FCC Lic KE0TDD, Nitrogen inflated 33" BFGoodrich All-Terrain T/A KO2s, FlexFuel E-85 conversion, AFe lifetime filter, Savage Offroad rock sliders, Ryno All Terrain 4.5mm skid plates, Line-X coatings on the armor, LifetimeLED & Rigid Industries LED headlights, UltraGauge 1.2, T3q 4.10 eLocker with armor from LROR, AmsOil lubricants used throughout. CBI plate rear bumper with swingaway, SPC Light Racing UCAs, ARB SS170HF Safari snorkel w/ Afrikaans centrifugal pre-cleaner, Tacoma antenna mod, TRD Supercharger w/ URD 7th inj. & URD pulleys, Anti-Dark engine bay lighting system. Having gone 250k, Aug 2016 was the time to replace the original clutch & get the driver's seat rebuilt/stuffed. Front & back Weathertech liners. '05 Tundra front disc brake swap. Full length Rocky Mountain Rack with 40" lightbar, Alternating strobe rear dust lights. I used a warm weekend in March 2022 to finally install my brand new from old stock 2000 4Runner driver's seat. $800 directly from the factory in Sapporo, Hokkaido, Japan.
    My in-cab install was exactly the same, same CB. at least it's only a pain in the ass once. It holds together surprisingly well in subsequent center console dismantle & refits.
  7. Jan 13, 2016 at 3:35 PM
    ramonortiz55
    Ramon
    Texas
    stock
    Nice!
    do you have a build thread?
  8. Jan 13, 2016 at 3:36 PM
    ramonortiz55
    Ramon
    Texas
    stock
    Okay, i see you have an RTT on your profile pic.
    How do you get it up there?
    I have one too and I have no clue on getting it up there. :anonymous:
  9. Jan 13, 2016 at 4:08 PM
    adanfon
    adanfon YNWA
    Adán
    Hanford, CA
    '11 Tacoma DCLB 4x4
    That looks clean Brotha!!!
  10. Jan 13, 2016 at 4:09 PM
    ramonortiz55
    Ramon
    Texas
    stock
    Thanks!
  11. Jan 13, 2016 at 4:28 PM
    Husky Driver
    Kipp
    Nope, no build thread. I had a mechanical engineer design & fab a custom rack with wind fairing that bolts on to the existing 10 OEM roof rack slide nuts with 1" clearance. What passes for my build thread is the up to date description in my profile.
  12. Jan 13, 2016 at 4:33 PM
    ramonortiz55
    Ramon
    Texas
    stock
    No, I meant how do you set the RTT up there?
    Crane? Drop it down from the roof?
    Rattletrap66 likes this.
  13. Jan 13, 2016 at 5:47 PM
    Husky Driver
    Kipp
    The engineer & I just lifted the tent & rack from either side & lifted it up there. It worked out to 80# each, so it wasn't easy but it was only a minute or so from table to roof. What I need is the dash plate you used for the switch panel under your stereo.
    ramonortiz55[OP] likes this.
  14. Jan 13, 2016 at 5:55 PM
    ramonortiz55
    Ramon
    Texas
    stock
    join our BS thread for 4runners.. esp 3rd gens. :stirthepot:
  15. May 2, 2016 at 7:12 AM
    Jayjayb96
    Jayjayb96 Well-Known Member
    Jay
    SF Bay area, Ca
    02 4runner
    Sc'd. Arb rear locker, compressor, toytec coilovers w/eibach 600 lb springs, ome 890s, lc oem shocks, toytec panhard bar drop, ss extended brake lines, spidertrax 1.25" spacers, 275 70 bfg ko2 on scs sr8s, deckplate, isr, andymod 2.0
    Great write up. I will do this eventually.
