Installing Climate Control
Discussion in '3rd Gen. Tacomas (2016-2023)' started by salmonmigration, Jun 25, 2018.
  1. Jun 25, 2018 at 9:55 AM
    salmonmigration
    salmonmigration [OP] Well-Known Member
    2018 TRD Sport 6MT
    My Truck was built without the premium or tech packages, but due to differences in metabolism between myself and the other one I've been regretting not going for the dual-zone climate control.
    There's a couple threads on this topic from years ago and the general opinion is that it's too hard, but no actual specifics.
    Does anyone know what parts will be needed to convert the standard A/C setup to climate control? Specifically what behind the dash is needed? A new blend door setup?
  2. Jun 25, 2018 at 9:57 AM
    phsycle
    phsycle Well-Known Member
    CA
    Yeah, the cheaper route here would be to trade in your truck. Save yourself the headache, money, time, frustration, agony, marriage/relationship, etc.
    HutchJ, shakerhood, Garyji and 4 others like this.
  3. Jun 25, 2018 at 9:59 AM
    salmonmigration
    2018 TRD Sport 6MT
    Again, I want to know some specifics. There's not that many parts in the climate control system. If it's that hard there's a reason for it.
  4. Jun 25, 2018 at 10:02 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I would honestly say the conversion would cost you several thousand dollars. It's easier telling you what you won't need, like condenser, evaporator and compressor. What you will need is everything else. Also, what computer controls it? ECU? Is the logic already in there? My wife's new Highlander has dual zone and it's pretty sweet but it is totally different than my manual unit. To begin with there will be two blend points which will require different ducting. Then there will be the actual controller. Then there will be access to the PID loop that will control the actual temperature...
  5. Jun 25, 2018 at 10:08 AM
    phsycle
    CA
    Here is a write up for a Tundra: You need some tech skills/knowledge and lots of time for research. And remember that Tacoma's haven't been around as long as the Tundra's, so if you're looking for donor parts, they may be harder to come by. Overall, seems like way too much hassle, too many little quirks (the guy mentions them towards the end of the write up), and the fact none of this will be covered under warranty....good luck and have fun going down that rabbit hole.
    hiPSI likes this.
  6. Jun 25, 2018 at 11:00 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I just read that write up. Geez. Here's what I got from it:
    1. He bought a lot of used parts and cut up a lot of existing parts.
    2. After he was done, it still didn't operate like the original factory unit. He had to reset the temps every time.
    3. He spent close to $1K on used parts
    4. He has absolutely no warranty and won't have any warranty on any of the HVAC system like the compressor.
    I guess if you had all kinds of time on your hands and were satisfied with a system that "sorta" worked then this mod is for you. I would just get what I wanted even if I took a loss to get it. I do agree, that venturi tube is crucial to making it work and you cannot fab it yourself.
    shakerhood and phsycle[QUOTED] like this.
  7. Jun 25, 2018 at 11:07 AM
    pinochle
    pinochle GC8 Fanatic
    NNJ
    2018 TRDOR DCSB 4x4 6MT
    NFab Nerf Steps, Bakflip MX4, Profile 5500K HIDs, Kicker Tweeters, Toyota Bed Mat, XPEL Ultimate Paint Protection, Borla S-Type Catback Exhaust, ME-SO Customs Gasshole, ME-SO Customs Total Tails Stage 1, ME-SO Customs Ultimate LED Turn Signals V4, HELLA Supertones, OVTuned 2.0, 2LO Mod, 16x8 0mm Enkei RPT1 Wheels in Titanium Gold, Diode Dynamics SS3 Pro Foglights, K&N Cabin Air Filter, HPS Intake Hose, Amsoil Gear Lubes in 6MT, front and rear differentials, XPEL Prime XR Plus Tint, TRD Engine Air Filter, Pioneer Head Unit, 275/75R16 Falken Wildpeak A/T3W Tires, RallyArmor UR Flaps
    Get a blanket?
    kgilly, hiPSI, daddy_o and 1 other person like this.
  8. Jun 25, 2018 at 11:14 AM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Couldn´t you just open or close and turn the vents accordingly. We have the dual climate control on our Rav4 and most of the time it stays on sync anyways, because on a road trip the air is essentially mixing in the vehicle. We have found that by selecting a temp between the one each of us prefers then one can close or turn the vent as needed. Just my personal experience, but we don´t use the dual zone climate or the moonroof a whole lot, so not having it on my truck is not a big deal at all.
  9. Jun 25, 2018 at 11:21 AM
    OriginalMan
    OriginalMan Well-Known Member
    Oahu 808
    2017 TRD OR 4x4
    Bilstein 5100/888; 5160/AAL; SCS Ray10 Limited Gold; 285/70 Cooper STT PRO; AVS; OVTuned; Prinsu Cabrac; RCI Bedrack; TC Bed Stiffner
    Although auto climate is nice to have, it’s best to trade your truck in for an updated with bells and whistles already installed. I honestly have no issue owning just a basic taco OR version for playtime and work use. I have a luxury vehicle for comfort use with the family.
    DA3 likes this.
  10. Jun 25, 2018 at 11:40 AM
    Kheiron
    Kheiron @Koditten Pirate Radio member #003
    Kevin
    Powell, WY
    2017 OR DCSB QS
    Kenwood d710g, high speed pheasant mod
    Seems easier to trade the truck in, dude. I love my dual climate control.
  11. Jun 25, 2018 at 12:09 PM
    Shmody
    Shmody Active Member
    KANSAS CITY
    2018 Tacoma TRD Sport
    With a decent understanding of the HVAC systems in vehicles I do not see this being easy or even worth it. If you are serious about attempting I would work on getting a breakdown/diagram and see where the doors or located and if there is even space within the system to add more doors. Then you get into the electrical/controller side and I don't even want to imagine what headaches could come from that. I don't see anything being plug and play. You'd likely need to reprogram what ever computer controls the system.
    Like many of said. I've had dual controls on every vehicle I've owned. Almost always stayed on the same temp and if anyone had a problem they would move the vent or close it.
    If it's really that big of a deal trade her in and cut your losses.
  12. Jun 25, 2018 at 12:30 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    279FDC96-E283-4111-B12C-821CA2A7FFB5.jpg 0CA4FA52-0D26-457E-8B93-94156CD29BAC.jpg
  13. Jun 25, 2018 at 12:46 PM
    Clearwater Bill
    Billy
    Largo Florida
    Auto temp control and dual zones are two different things.
    For example a house with a traditional central system has a temp based tstat, but not different zones.
    And while dual zones in a vehicle may create different nozzle temps, after a few minutes the overall air temps begin to average out anyway. Its not like there are discreet air chambers in the vehicle.
    Just close the vents blowing on the cold person. The hot person will get more air flow and it will be just as cold as a zone system, as it will never get below 40ish regardless.
    Most times those hot flashes end quickly then they are freezing. A miserable condition to have (like a raging flu fever) but maybe not worth spending a fortune on. Because regardless, they will never really be comfortable.
    Or maybe a NASCAR cool suit? ;)
    As far as costs, i had an 86 300zxt and a 90 300zx, both with auto temp. All I can say is i'm glad they worked fine manually when the control systems failed, as parts costs were prohibitive!
    hiPSI likes this.
  14. Jun 25, 2018 at 1:00 PM
    OriginalMan
    Oahu 808
    2017 TRD OR 4x4
    Do you know if he’s done the AC drain mod yet? :D:rofl:
    MESO and HutchJ like this.
  15. Jun 25, 2018 at 3:26 PM
    flipnidaho
    flipnidaho Well-Known Member
    2001 Tacoma Double Cab TRD
    I have 2 Tacos. One with dual climate and one with single control (both 2018's). Even though the dual climate is nice, 98% of the time, the temperature is set at the same level for both sides so i think the utility for dual climate control is meh.
    2016Tacoman and daddy_o like this.
  16. Jun 25, 2018 at 3:57 PM
    phsycle
    CA
    Yup, it's NICE to have, but not a necessity. I do like it when my wife rides with me. She gets cold at anything below triple digits and I sweat in the middle of winter. Nice to have cold air blowing in my face while my wife has the heater going with the heated seats on. Even with others in the car, sometimes the passenger side is in the sun, or my side, and to have dual side temp control is nice. I'd no real issues going back to a manual control CC, but it's nice to have the DZ auto.
  17. Jun 25, 2018 at 8:41 PM
    Rus$
    Rus$ Well-Known Member
    Russ
    2018 Tacoma DCLB AT TRD Off Road
    I’ve been looking into it purely for the auto temperature function. I got a used control for $40 so I plugged it in. No function except for the flashers. From that I’m guessing it’ll have to be rewired. Going to look into making an adapter harness. I’ll update you if I make any progress.
  18. Jun 26, 2018 at 6:21 AM
    bv8ma
    bv8ma Well-Known Member
    Bill
    MA
    2017 TRD OR
    My last car had dual climate control and the auto climate control, I never used either feature.
    2016Tacoman likes this.
  19. Jun 26, 2018 at 7:49 AM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    My climate control is always set to minimum. Just adjust vents and fan speed. Quite useless for me.
    Same with bsm and safety sense which Imo will see major changes over the years.
    You probably won't even want to use it if it's still working in 10 years it will be so antiquated.
  20. Jun 26, 2018 at 7:54 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    We have dual zone and 95% of the time my wife just closes her vents and doesnt change the temp.
    bv8ma likes this.
