Installing Driver's Side Valve Cover
Discussion in '1st Gen. Tacomas (1995-2004)' started by ztwatson, Aug 29, 2023.
  1. Aug 29, 2023 at 7:30 AM
    ztwatson
    ztwatson [OP] Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    Anyone have any tips for removing/installing the driver's side valve cover? That thing is quite difficult to get out. Looking for something to help get it back in without risking damage to other parts.
  2. Aug 29, 2023 at 11:17 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    I find that loosening any wire looms and hoses that are in the way definitely helps. If my memory serves me right, I had do a bit of gymnastics by sliding it in versus placing it on top directly.
    MalinoisDad likes this.
  3. Aug 30, 2023 at 12:27 AM
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    Think you gotta pull the air plenums. Makes it easy. Make sure you get 2 new gaskets for them.
  4. Aug 30, 2023 at 4:12 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Any more I can only remember this when looking at the engine.
    The different engines all kinda blur together after all these years.
    I can say I would remove anything in the way to make things easier.
  5. Aug 30, 2023 at 10:34 AM
    ztwatson
    Milwaukee, WI
    Thanks guys. Freed up the wiring harness in a few additional spots and that gave me enough room. Should've mentioned this was on a 3.4L V6.
    Bivouac likes this.
  6. Aug 30, 2023 at 10:39 AM
    Bivouac
    I think Drivers side Valve cover narrowed it down to some sort of V6 or V8.
    Then you did not mention any swap so that pretty much says 3.4 by the year.
