Installing Fox 2.5s - Thread adjustment help/question
Discussion in 'Suspension' started by FStewart17, Aug 26, 2017.
  1. Oct 23, 2017 at 6:26 AM
    #41
    TravoHTX
    TravoHTX 2017 TRD OR
    Travis
    Westminster, Colorado
    So without making a new thread, I'll jump into this one with my question;
    I have the same Fox 2.5 ext. travel coilovers and want to adjust them. I see this guy had 3 inches of thread showing and Fox said that was fine. I think I'm at about 1.5-2 inches of thread showing. I need to raise mine a bit to correct some rubbing issues temporarily. I've read multiple threads where people have said you can adjust them by jacking up the front, loosening the set screw and using a punch or screwdriver to adjust the collar. Some other people say that you need to take the coilover completely off the truck to safely adjust them. Another person said to use a spring compressor on the truck but then another guy said a spring compressor wont fit around the Fox coils. I'm getting mixed responses to the question :\ Can anyone chime in, I really don't want to hurt myself or my investment.
    Thanks!
    pauldncali and Biscuits like this.
  2. Oct 23, 2017 at 7:33 AM
    #42
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    Buy the Fox spanner wrenches, while a bit expensive, you will not damage the preload/backup rings. You can tighten them while installed on the vehicle.(jacked up off the ground) but you must remove the coilover to loosen them.(at least with the reservoir version)
    Whoops, set screw must be a newer version, same idea without the backup ring.
    PNWskibum likes this.
  3. Oct 23, 2017 at 8:04 AM
    #43
    TravoHTX
    Travis
    No remote reservoir on there, just the coilover with SPC UCA's. So you think its safe to jack up the front, loosen the set screw and try to tighten down the collar?
  4. Oct 23, 2017 at 9:10 AM
    #44
    Broheim
    Broheim Well-Known Member
    San Antonio, TX
    2023 TRD Pro
    I did.
    Jacked it up and was able to turn the collar. I used a spanner wrench. Not sure if I would have tried this using another tool. Just throw some wd40 on there and it'll spin...not easy..but it'll turn.
  5. Oct 23, 2017 at 9:12 AM
    #45
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Any of you guys have issues with the threads on the collar rusting, or any part of your 2.5's?
  6. Oct 23, 2017 at 9:12 AM
    #46
    ToyotaRoamer86
    ToyotaRoamer86 Well-Known Member
    Brandon
    Frisco, CO
    2007 Tacoma TRD Sport
    installing mine tonight, non resi. I'm stoked and hopefully no issues.
  7. Oct 23, 2017 at 9:25 AM
    #47
    neonlazer
    Lafayette, LA
    '23 DCSB 4x4 SR5
    I have adjusted mine multiple times without issues. I just spray kroil on it to keep things clean and lubed.
  8. Oct 23, 2017 at 10:43 AM
    #48
    ToyotaRoamer86
    Brandon
    Frisco, CO
    I bought my front kit used and have no bolts or washers.
  9. Oct 24, 2017 at 8:51 AM
    #49
    ToyotaRoamer86
    Brandon
    Frisco, CO
    Installed, no issues.
  10. Oct 24, 2017 at 9:12 AM
    #50
    Broheim
    San Antonio, TX
    2023 TRD Pro
    pics?
    what did you use for the rear?
  11. Oct 27, 2017 at 1:54 PM
    #51
    ToyotaRoamer86
    Brandon
    Frisco, CO
    @Broheim I'm waiting on my ALLPRO Expedition kit
  12. Oct 27, 2017 at 3:57 PM
    #52
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    Much easier with a right size (8 mm) punch than with spanner. At least in the newer (one ring) version. With or without the resi, no matter.
    17SandTaco and WPNZ like this.
  13. Dec 16, 2017 at 12:17 PM
    #53
    ivanza
    ivanza Well-Known Member
    Bay area, CA
    2017 MGM TRD OR MT
    Mobtown skids Fox 2.5 DSC OME heavy leaf
    I just went to install the rear shocks. The bushing steel sleeves are longer than the rubber bushings. Is this normal? I would assume it would be flush
  14. Dec 16, 2017 at 3:22 PM
    #54
    Broheim
    San Antonio, TX
    2023 TRD Pro
    The Fox rear shocks come with different size bushings in the box. Just swap them out.
  15. Dec 16, 2017 at 4:32 PM
    #55
    ivanza
    Bay area, CA
    2017 MGM TRD OR MT
    Mine didn't.
  16. Oct 3, 2018 at 1:01 PM
    #56
    D.W.B
    D.W.B Well-Known Member
    Dennis
    Mar Vista, CA
    TRD OFF-ROAD
    My measurements:
    Driver: 23" from hub center to fender, 2" of treads showing.
    Passenger: 23" from hub center to fender, 1" 9/16 of treads showing
    I'm probably going to crank a little bit more to get 24" even.
    How are you guys setting up the blue and gold knobs for street driving? I'm having a hard time understanding what I have to do exactly.
  17. Oct 3, 2018 at 1:07 PM
    #57
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Low speed vs high speed is in terms of piston speed. Low speed will take care of the city driving and body roll type of stuff. The high speed is for big bumps / holes.
    I run two separate settings for off road and one for on road. I'd like to say on road I'm still 4LS-6HS. I'm also lighter than most rigs so I don't need to crank it.
  18. Mar 17, 2019 at 3:41 PM
    #58
    cjankows
    cjankows New Member
    Sorry to revive an old thread. D.W.B what did you end up cranking your coilovers to?
    I'm currently where you started at:
    Driver: 23" from hub to fender with 2" of thread
    Passenger: 23" from hub to fender with 1" 9/16 of thread as well.
    I'm also looking to get up to 24". Was thinking about going to 2.5" of thread on the drivers side and a touch less on the passenger side. Been using a punch so far but one hole is getting ovaled, so I was thinking about picking up the fox spanner wrench. I heard the fox spanner wrench won't fit well in the bucket if you have the reservoirs? Have you guys had better luck with the spanner wrench?
  19. Mar 17, 2019 at 8:29 PM
    #59
    zippo88
    zippo88 Well-Known Member
    L
    2012 sport
    Use 2 punches.
  20. Mar 20, 2019 at 2:28 PM
    #60
    drewhaus
    drewhaus Well-Known Member
    Andrew
    El Granada, CA
    2018 Tacoma
    Check out this thread, way more info there.
    https://www.tacomaworld.com/threads/fox-life-anything-related-to-foxs.536036/
