Installing gauges on 2018
Discussion in '3rd Gen. Tacomas (2016-2023)' started by UYough, Apr 2, 2019.
  1. Apr 2, 2019 at 5:00 PM
    UYough
    UYough [OP] Member
    2018 tacoma Access cab V6
    none yet
    I have a 2018 SR5 access cab. I want to install gauges (volt, water temperature, oil pressure). I was told by one mechanic gauges cannot be installed because of the electronics/computer software. The guy said if someone comes up with a way of bypassing all the electronics then it could be done. Is he right? Could I install an oil gauge, a simple mechanical, plastic line from block to pressure gauge with a "T" plug in the engine block.
    Thanks.
  2. Apr 2, 2019 at 5:08 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Why would do that install gauges when you can get all that information from the obd2 port and Bluetooth it to your phone or tablet plenty of companies selling the adapter and software to view in real time.
  3. Apr 2, 2019 at 5:13 PM
    UYough
    UYough [OP] Member
    none yet
    thanks for the quick reply. The Bluetooth I didn't know you can do that. That said...I rather look at gauges o the dashboard.
    Rujack likes this.
  4. Apr 2, 2019 at 5:17 PM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    Can’t get oil pressure from stock sensor
  5. Apr 2, 2019 at 5:58 PM
    Shellshock
    Iowa
    Get a scangauge. It’ll do everything you listed
  6. Apr 2, 2019 at 7:54 PM
    Rujack
    Can it read oil pressure? I thought the stock sensor on the 2gr fks was only a low pressure sensor; ie not dynamic...
  7. Apr 2, 2019 at 8:09 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Check out Banks iDash
  8. Apr 2, 2019 at 8:28 PM
    sabersoul1217
    sabersoul1217 Well-Known Member
    Jeremy
    Friendswood, TX
    2021 F-150
    I'm certain you likely can. I did it in my '03 Neon. You just need to know the size fittings. I installed a "T" on the block, the stock sending unit on the bottom and the AutoMeter sending unit on the end opposite end from the block. Like this:
    Block T AM Sending unit ------ Gauge
    Stock Sending unit ------ Vehicle wiring
    As far as what size fittings you'd need, I don't know. And I would use an electro-mechanical gauge so you only have to run a single wire through the firewall and not an oil tube.
  9. Apr 3, 2019 at 12:56 PM
    UYough
    UYough [OP] Member
    none yet
    Shellshock: BIG thank you for the scangauge. It can tell you a lot. So to look at coolant temperature, you press the bottom, to look at oil, you press the button, to look at volts you press the button
    Shellshock[QUOTED] likes this.
  10. Apr 3, 2019 at 12:57 PM
    UYough
    UYough [OP] Member
    none yet
    What is Banks iDash?
