installing headers
Discussion in 'Performance and Tuning' started by Joeymgd78, Dec 31, 2011.
  1. Dec 31, 2011 at 5:15 AM
    Joeymgd78
    Joeymgd78 [OP] Well-Known Member
    Joey
    at the moment Afghanistan
    2008 Tacoma SR5 TRD Offroad 4.0 V6 Double Cab
    does installing headers require any welding
  2. Dec 31, 2011 at 5:17 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    The Short tubes do, the long tubes do not
  3. Dec 31, 2011 at 5:32 AM
    Joeymgd78
    Joey
    what is the difference in proformance between lon and short? long is for offroading right
  4. Jan 1, 2012 at 2:58 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Long tubes are not strictly for off roading. They are just labeled as such due to the fact that they remove the front two cats. Thus they don't meet emissions standards in most places, and have to be labeled as,"for off road use only".
    Better performance over stock. Direct bolt on. Shorties required welding on the factory cats from the factory headers.
  5. Jan 1, 2012 at 3:02 PM
    ShaydenandDiezel
    ShaydenandDiezel Well-Known Member
    Hawaii
    TRD
    6 inch Pro Comp Suspension Lift. K&N intake. Air Raid throttle body spacer. 20 inch XD Diesel rims. 33x13.50 Irok tires. Single in dual out exhaust with SS tips.
    Long tubes provide more torque versus stock. Short tubes provide more horsepower.
  6. Jan 1, 2012 at 3:18 PM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    The biggest thing is where the power is at on LT versus Shorties. A LT header will cause some loss (or sometimes no loss but no gain) down low and mid range but will see a much larger gain in the higher RPM's. The Shorties will have the biggest gains low to mid RPM with some (if any) loss higher RPM's.
    Also, LT headers are bolt up and remove the front set of cats but require an O2 simulator to not throw a CEL code and are not street legal in most places. Shorties do not require a 02 Sim as you must weld on your front cats directly onto the headers.
    I will be going with shortie headers because I am supercharged and I want more power down low when wheeling and towing. I dont spend much time 3-5k RPMs anyways.
  7. Jan 11, 2012 at 8:26 PM
    MtnRanchtaco
    MtnRanchtaco New Member
    CA central sierra foothills
    boondockin' wood haulin' fun 4x4
    NWOR tri-Y header & front springs,dynoflow super turbo muffler w/K&N filter
    I bought the NWOR.com tri-y header.Beautiful welds highest quality,w/dynoflow super turbo muffler...great sound and as for performance ....it's amazing ! Improved throttle response."Pulls" a lot harder thru 2nd,3rd & 4th.Not down shifting going up grade that I had to before the header.. only one glitch on the install ...the solid brake line is in the way and needs to be Gently bent towards to frame for clearance or if NWOR re-routed #1 tube up and around that problem.Otherwise perfect high performance header.
  8. Jan 11, 2012 at 8:34 PM
    TACOsupremacy
    TACOsupremacy Well-Known Member
    Gaven
    Aiea_Hawaii
    05taco
    Never satisfied
    Long tubes ftw!!! no loss of power anywhere.. all gains, especially with the URD tcai :D
  9. Jan 11, 2012 at 8:38 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Its true unfortunately, but a custom tune can correct for most of the power loss in the low end.
    Thats usually what the guys over on xr-u do
  10. Jan 11, 2012 at 8:39 PM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    ^^^true, its not a signifigant amount though. the good ol' butt dyno wont be able to tell a difference
  11. Jan 12, 2012 at 6:19 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    A custom tune using what box/tuner?
  12. Jan 12, 2012 at 6:56 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Theres a few different options, but if you plan on just the exhaust and no Boosting in your future, then the URD MAF CAL is the best bang for your buck.
    You know the difference between a standard tune map and a custom tune map right?
  13. Jan 12, 2012 at 7:53 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Yup, I was just trying to figure out what you meant as I don't consider the MAF Cali as a custom tune, but it's more a definition thing, nothing to get hung up about. I think we're good. Also wanted to ensure that custom tune wasn't restricted to the APR X1 since that is only useful for pre-09s.
  14. Jan 12, 2012 at 8:01 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    You have an 09? Google "UCON EMS"
  15. Jan 12, 2012 at 8:30 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Appears that I need to start hanging out on XRU too, as I totally missed this. Very curious about price points and the 09+ harness.
  16. Jan 13, 2012 at 6:35 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Gadget is working on making plugs that fit the '09 ecu. That will be there to make a plug in play ecu for the '09 or a plug in play extension harness.
    My friend is having ProEFI make a flying lead harness that has to be wired in (instructions included) for the '09 ecu. Therefore he can and will be running ProEFI's Pro48 ecu.
    Just another option as far as tuning is concerned.
  17. Jan 13, 2012 at 11:59 AM
    toon714
    toon714 Well-Known Member
    toon
    So. Cali to H-town
    2010 turbo lowered prerunner
    garret Gt 35R front mount turbo, TR lowering kit, Work wheels, all the go fast goodies!
    pro efi ftw!
    gonna finally put some numbers down with this front mount turbo.
  18. Jan 13, 2012 at 12:05 PM
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    Very interested ^ :popcorn:
  19. Jan 13, 2012 at 12:13 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    have we seen any actual #'s of the LT vs ST headers on the 2nd gens?
  20. Jan 13, 2012 at 12:17 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Dito Novanut. I will also bring some beverages for the big :cheers: afterwards.
    I can bet that you are about tired of driving like > :turtleride: over the past few months. That would make most people go....:annoyed:
