Installing HIDs... have question.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by soilsample, Mar 7, 2010.
  1. Mar 7, 2010 at 12:41 PM
    soilsample
    soilsample [OP] Well-Known Member
    Donald
    Southwest Louisiana
    '09 4x4 Double Cab
    Hi everyone,
    Installing the harness for my HIDs. Instructions are garbage.
    On he Hi/Low controller harness, there is a 3 prong male connector that the directions don't show a home for.
    Is this a relay plug that will go into the fuse box or something??? Any advice on where this plugs would be great.
    Thanks
    Donald
    Here is the plug in question:
    Instructions don't show it going anywhere.
  2. Mar 7, 2010 at 12:50 PM
    blazze2005
    blazze2005 Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    Please post some pics of that harness and what u are describing
    I just finished installing my hid kit and will be happy to help you out
  3. Mar 7, 2010 at 12:56 PM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    that should be the plug that connects to the diverside headlight bulb plug, that is where the power come from to power the hids.
  4. Mar 7, 2010 at 12:57 PM
    soilsample
    Donald
    Southwest Louisiana
    '09 4x4 Double Cab
    Post updated with picture of plug.
  5. Mar 7, 2010 at 12:57 PM
    soilsample
    Donald
    Southwest Louisiana
    '09 4x4 Double Cab
    Ok Thanks!!!!
  6. Mar 7, 2010 at 12:58 PM
    blazze2005
    South Jersey
    Dellosa89 is correct!
    Here is a photo from my 05 tacoma of where you will plug that into the back of the headlight on the drivers side...
    It's a brown plug
    The passenger side headlight plug can just be capped off with electrical tape
  7. Mar 7, 2010 at 2:02 PM
    blazze2005
    South Jersey
    Soilsample,
    Curious' what brand HID kit did you buy for your tacoma and where did you get it?
  8. Mar 7, 2010 at 3:06 PM
    soilsample
    Donald
    Southwest Louisiana
    '09 4x4 Double Cab
    It's Apexicone from DDM
    Got everything hooked up and works fine!
    Thanks for all your help!
  9. Mar 7, 2010 at 3:11 PM
    blazze2005
    South Jersey
    your welcome! Any pics of your HIDS at night?
  10. Mar 7, 2010 at 4:16 PM
    Frankiea87
    Frankiea87 Member
    nerf bars, 15% window tint. TRD shift knob.
    whats the difference between apexcone raptor kit and the DDM slim ballast kit?
  11. Mar 7, 2010 at 5:05 PM
    TRDKenE
    TRDKenE DAMN GOOD DEAL!!
    Kenny
    Richmond, Virginia
    '10 D-CAB OFF-ROAD 4X4
    TRD CAI, GrillCraft.
    I believe the Slim ballast are digital which give you a quicker warm up time. The others are regular ballast. Im sure if Im wrong someone will chime in and correct me
  12. Mar 8, 2010 at 3:03 AM
    it's in coma
    it's in coma Well-Known Member
    in the desert
    06 trd off road
    intake and exhaust
    so, the passenger's side stock h4 connector stays unplugged? that doesn't sound right? can someone explain please?
  13. Mar 8, 2010 at 5:07 AM
    blazze2005
    South Jersey
    Yes it is right....You only need to feed the power to one side (driver side)
    The passenger side factory brown H4 plug just hangs unused. You just cap it off with some electrical tape.
    What I don't understand is why don't these companies give you a cap to cap off the unused factory plug?
    I made my own (H10 plug cap) when I did my HID fog light conversion on my fogs
    My bulbs had the extra male connector so I just pulled the wires out of the end of it and filled it with silicone
    Here's a pic of how I capped off the H10 plug on my factory harness
  14. Mar 8, 2010 at 5:14 AM
    soilsample
    Donald
    Southwest Louisiana
    '09 4x4 Double Cab
    Well....
    I ordered the slim ballast kit.
    The ballasts are small, but the kit has apexicone decals inside.
    These are obviously made in China.....
    Hope they last.
    I can't find any indication of bulb temp on the packaging, but they look like the right color temp.
    Light output is very good.
