Installing Husky Mudflaps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kb1jop, Apr 14, 2012.
  1. Apr 14, 2012 at 4:50 AM
    kb1jop
    kb1jop [OP] Well-Known Member
    Rick
    Springfield, MA
    2010 Barcelona Red 4WD DCSB 6-Speed SR5
    Factory Towing Package Factory Roof Rack OEM Bed Mat Trifecta Tri-Fold Tonneau SeatSaver Custom-Fit Seatcovers WeatherTech Custom-Fit Floor Mats Block Heater: http://www.metrotpn.com/ProductDetails.aspx?CollectionID=13&ProductID=191&SortIndex=9
    Just received my Husky mudflaps. Instructions show 5 mounting points. Flaps only have 4 holes.
    Someone mentioned having to poke an extra hole. Where do I do this? Or will it be obvious if put on the other mounts first?
    Don't want to screw this up. Any help would be appreciated.
    :confused:
  2. Apr 14, 2012 at 9:12 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    You need to step away from the tool box! :D
  3. Apr 14, 2012 at 11:59 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    If you still have your old mud flaps you can use them as a template. I "eyeballed" mine. The fifth hole is not really necessary though
  4. Apr 16, 2012 at 5:10 AM
    kb1jop
    Rick
    Springfield, MA
    What does this mean?
    I actually went into my toolbox and found a bevel gauge to detect the angle relative to the next closest hole. Not sure what you were telling me. :confused:
