Installing Kenwood 8120 and scosche dash kit
Discussion in 'Audio & Video' started by LonghornTaco, Nov 26, 2008.
  1. Nov 26, 2008 at 6:29 PM
    LonghornTaco
    LonghornTaco [OP] Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    I can't seem to figure out how to get the dash kit on. The trim ring doesn't seem to fit.
    Also, do you use the metal brackets off the stock stereo or the plastic ones in the dash kit? Does it matter?
    Help!
  2. Nov 26, 2008 at 6:58 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    Duct tape my friend, Duct tape.
    Just messin. I will be installing my stereo end of the month so i'm going to keep an eye on this thread for pointers.
    Thanks :thumbsup:
  3. Nov 26, 2008 at 7:06 PM
    moserjjx
    moserjjx Tacoma Newbie
    Eau Claire, WI
    08 DC TRD 4x4
    Weathertech liners, bed mat, rear spring TSB, extra 12V outlets in center console, seat belt chime off
    does the radio not stick out of the dash kit far enough to snap on the trim ring? does it stick out too far? can you be any more specific or maybe snap a quick pic?
  4. Nov 26, 2008 at 8:30 PM
    LonghornTaco
    Minnesota
    Ok, finally got it! I guess it's been a really long time since I installed a car stereo. Last time I did it, dash kits were a lot simpler than they are these days...
    The problem was simply a matter of what order I put stuff on. And (at least with the Scosche kit) you can't use the metal brackets, you have to use the plastic ones it came with.
    So, the order is (if this makes sense):
    Dash Kit
    Put the plastic brackets in place in the dash kit
    Put on the trim ring
    Slip the stereo into the brackets and bolt them on
    Slide the whole thing back in to place in the dash
    When I take the stereo back out next week to wire up the amps, I'll try to snap some pics of the order in which it is put together. Cause the "directions" sure's hell don't describe it very well... :)
    Here it is installed!
  5. Nov 26, 2008 at 8:33 PM
    moserjjx
    Eau Claire, WI
    08 DC TRD 4x4
    looks great - love the double din setup. looks like it belongs there! the last few radios in installed were kinda fussy to get the depth just right but enough messing around with the brackets made it work. haven't done my truck yet so a picture "schematic" would be a nice addition!
    did you have the stock JBL system? if so, did you get the special JBL wiring adapter?
  6. Nov 26, 2008 at 8:34 PM
    rhoppas
    rhoppas Land of Oz
    Topeka, KS
    07 Double Cab V6 TRD Sport Tow
    Earnhardt Cannons, Terra Grapplers, Viper alarm, Hunter4x4 Bull Bar, 6" Pro Comp Off-Road lights, extra set of bed D-rings, Chrome exhaust tip, Metra Ipod/MP3 adapter, Garmin GPS, CarriageWorks grill, Maglite mounted to driver seat, 9" Stubbie Antenna, WeatherTech floor liners, Saddleman Neoprene seat covers, DeeZee bed mat
    Looks really good Jason!
  7. Nov 26, 2008 at 8:37 PM
    LonghornTaco
    Minnesota
    Nope, no JBL.
    Also, ground out the parking brake wire and I'm good to go watching porn while I drive! :)
    You know, the first three vehicles I ever saw with video screens (back in the late 90s) were all three playing porn... :eek:
  8. Nov 26, 2008 at 8:41 PM
    moserjjx
    Eau Claire, WI
    08 DC TRD 4x4
    porn in your truck? awesome. might have to move the new radio up on the (very long) mod list!
  9. Nov 26, 2008 at 10:21 PM
    bledsoe3
    bledsoe3 Well-Known Member
    Portland
    '15 DCLB Limited
    SnugTop, Air Lift bags, Bilstein 5100's up front, AAL in rear, 275/70/18 BFG AT TA KO2, URD TCAI, URD Cat Back
    I sold the factory JBL stereo. After the new stereo was in I had some sort of problem (I can't remember wat is was) and I took it back to the stereo shop. They told me I needed the factory metal brackets. They thought they lost them and ordered me new ones.
    This is just my experience. YMMV.
  10. Nov 26, 2008 at 10:25 PM
    LonghornTaco
    Minnesota
    I guess the metal brackets might work but they won't have the plastic "grooves" that make it snap into the dash kit. When I tried to use the metal brackets first it wouldn't fit. However, I was doing it in the wrong order. So you may be able to use them...
  11. Nov 27, 2008 at 10:26 AM
    Mingy
    Mingy Well-Known Member
    Milton, Ontario
    V6 uble Cab TRX/Towing
    Lear cap.
    Though I'm not sure I had the same dash kit.
    I had to remove about 2 mm off the inside top of the black plastic bezzle, otherwise the display wouldn't move properly.
    I used a sharp exacto knife, a file, and sandpaper.
    I had so many damned cables in there I'm surprised the head fit!
    Now if I could only figure out why the bluetooth handsfree stopped working ...
  12. Nov 27, 2008 at 10:27 AM
    Mingy
    Milton, Ontario
    Lear cap.
    A no connect on the brake worked for me ...
  13. Nov 27, 2008 at 12:04 PM
    MTL Tacoma
    MTL Tacoma Well-Known Member
    Montreal, Canada
    2016 DC LB TRD Sport
    Are you able to cycle threw all the different screen angles?
  14. Nov 27, 2008 at 12:23 PM
    LonghornTaco
    Minnesota
    I know it opens and closes completely, but haven't figured out how to change the screen angle. Couldn't find it in the manual...
  15. Nov 27, 2008 at 12:34 PM
    Mingy
    Milton, Ontario
    Lear cap.
    Monitor Setup, 2nd page.s
    Thats the problem I had, she wouldn't tilt to load a dvd, or reverse tilt (I got one or the other) until I trimmed the bezel
  16. Nov 27, 2008 at 12:36 PM
    LonghornTaco
    Minnesota
    Cool - I'll check it out.
  17. Nov 27, 2008 at 3:59 PM
    MTL Tacoma
    Montreal, Canada
    Go to steup, then monitor and I think its on the second page of options where you find the different tilt angles. The only one I can't do is the reverse tilt (-1), the installer said there wasn't enough "room" in the dash.
  18. Nov 27, 2008 at 9:52 PM
    LonghornTaco
    Minnesota
    Found it... Got the screen tilted and it looks even better!
  19. Nov 28, 2008 at 5:32 AM
    Mingy
    Milton, Ontario
    Lear cap.
    There's plenty of room in the dash. Its probably interfering with the bezel or something like that and your installer was either too lazy or wasn't able to figure out how to make it work. My does the full range of motion (including load the Garmin SD) after I modified the bezel. Prior to my mod I had to basically chose between tilt up or tilt down by moving the unit slightly as I tightened the OEM brackets. I never could figure out how to use the brackets that cam with my kit, and I figure the radio is better bolted in.
    By the way - everybody remember to set their PIN!
  20. Dec 1, 2008 at 5:20 PM
    Rippin101
    Rippin101 Well-Known Member
    Jax Beach, FL
    2014 TRD Sport 4x4
    -Nitto G2 265/70/17 -Level 8 MK6 Wheels -Katzkin Leather Black on Black -BHLM -Weathertech -Extang Solid Fold -Bedlight LEDs -TRD Skid
    I'm so excited to get my Kenwood this Christmas I can hardly wait! Whats the best way to go about bypassing the video part? Ground the parking wire? If so, to what?
