Installing leaf pack...e-brake line may be in the way
Discussion in '1st Gen. Tacomas (1995-2004)' started by JaSkynyrd, Jul 12, 2011.
  1. Jul 12, 2011 at 7:18 AM
    JaSkynyrd
    JaSkynyrd [OP] Ron F. Swanson
    Chattanooga, TN
    2001 XtraCab 4x4 V6 SR5
    My wife's grandfather (grandfather in law?) and I are working on lifting my truck. Right now at my house I've got all new shocks to go on it with 881 coils up front. I ordered a 3 leaf progressive AAL from wheelers that they said will be in around the middle of July, and I ran into a possible install problem. I searched around (Yay for me, right?) and found a good picture on TacoRojo's build. My e-brake cables DO NOT run in the same place as his, they run on top of my rear axle, I edited his picture with a red line showing where mine runs (You'll have to use your imagination and pretend that line doesn't run UNDER the leaf but OVER it). As they are now I don't think there will be enough room to squeeze the extra leafs in there, there's only about an inch of clearance between the cable and the top of the leafs.
    What should I do to get them out of the way for the added leafs? Is mine in the stock location and his in a modified location? How can I move them?
  2. Jul 12, 2011 at 7:25 AM
    Gregero
    Gregero TRD: Trail Ready Development
    Greg
    El Cajon, CA
    Blue '06 Prerunner TRD Sport
    LED Spyder Tail Lights, Debadged Tailgate, TOYOTA logo on Tailgate, Uniden Radio w/ 4' Ant., Removed Sway-Bar, Rear 5125s, 8" King Offroad Shocks, Debadged Doors, 1.25" Rear AllPro Wheel Spacers, 33x12.50R17 Mickey Thompson Baja MTZs, AllPro Skid Plate, New Car Smell Air Freshener, OMD Ford&Chevy Leaf Pack, Glassworks Front Fenders, Engage LT UCAs and LCAs, Engage HD Tie Rod Ends, Kar-Tek Limit Straps, Camber Eliminator Kit, Removed Rear Flares, Blue LED Dome and Map lights, LED License plate lights, Black TRD Sport Rims, MBRP Catback Exhaust, 20W PA Speaker, 2 Meter Radio, AFE Stage2 CAI, Demello-like Bed Bar, Harbor Freight Dust Lights, Blacked-out Hood Scoop, Custom Pre-Runner Bumper
    hmmm. thats kinda odd I think. I went outside and none of my lines run over my leafs. All run under. I'll edit with a pic in a second
    Here ya go (I know I need a bracket for those leafs)
    And here's a truck we were under yesterday. The lines all look to go under the leafs as well.
  3. Jul 12, 2011 at 7:26 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Mine is in the same place you should me fine I have a 8 pack with a U bolt flip kit and I still have room. There is a pin at the drum you can pull off to move them out of the way durring the install but you should have room.
  4. Jul 12, 2011 at 7:28 AM
    JLee
    Jerry
    Bay Area NorCal
    1st Gen bud.
  5. Jul 12, 2011 at 7:32 AM
    JaSkynyrd
    Chattanooga, TN
    I guess I won't know for sure until I actually get the leafs in there, but man I think it will rub.
  6. Jul 12, 2011 at 7:33 AM
    Gregero
    Greg
    El Cajon, CA
    Ah! Good catch, JLee! lol I tried :)
  7. Jul 12, 2011 at 7:35 AM
    JLee
    Jerry
    Bay Area NorCal
    Take a better picture of the line going over the leaf pack and I'll go a get a shot of mine this evening after work and we can see if you are in a same spot as mine. You might have a bent bracket.
  8. Jul 12, 2011 at 9:20 AM
    JaSkynyrd
    Chattanooga, TN
    I'll have to take one tommorrow, I'm not going by my his house till then, he lives a bit out of the way. I don't have the leafs yet, so I've got some figurin' time
  9. Jul 12, 2011 at 9:25 AM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    It will be close, but it will be fine. You just need to be careful as you feed the leaf in there. The line runs almost directly above the U-bolts, so the spring will never be able to flex up into the line.
  10. Jul 12, 2011 at 9:26 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Fail Douche boy !!!! :p
  11. Jul 12, 2011 at 9:26 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    mine go over the leaf pack as well... im very confused. sometimes the brake light will come on. quite often when weeling.
    EDIT: my e brake line on clearly resting on the leafs.
  12. Jul 12, 2011 at 9:29 AM
    JLee
    Jerry
    Bay Area NorCal
    Or you can just pull the pin and move the cable out of the way. That's what i did I wasn't trying to try and fish my 70lb leaf packs under the E-brake cable it comes off pretty easy.
  13. Jul 12, 2011 at 9:32 AM
    scocar
    Dick
    2015 DCLB 4x4 SR5
    Oh, look, I'm JLee and I like to do things the easy way...
    I would like to think that that is what I did, too, but I can't even remember. I do remember pausing at least and thinking WTF? This is going to suck. :homer:
  14. Jul 12, 2011 at 9:33 AM
    JLee
    Jerry
    Bay Area NorCal
    Humm what packs are you running? I'm running the Expos that are an 8 pack and mine are not touching. You guys might be able to bend the brackets that hold the cable in place but it's kinda hard to determine without seeing it. I'll look at mine tonight and let you guys know if there is a way to resolve this.
  15. Jul 12, 2011 at 9:34 AM
    JLee
    Jerry
    Bay Area NorCal
    :p:D
  16. Jul 12, 2011 at 9:37 AM
    97yota4wd
    Eric
    Mesa, AZ
    stock with a toytec 2 inch AAL. it was touching before the AAL also. i have a picture of my back shocks and you can kinda see the line.. hold on let me send it to tw live then put it on here
    mine is like bending over the leafs. when i first got the truck the light never came on. but after wheelin for a while it does now. i probablybent something lol...
  17. Jul 12, 2011 at 9:39 AM
    scocar
    Dick
    2015 DCLB 4x4 SR5
  18. Jul 12, 2011 at 9:43 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Not the best pic, don't know if it helps ya or not....:notsure:
  19. Jul 12, 2011 at 9:58 AM
    97yota4wd
    Eric
    Mesa, AZ
  20. Jul 12, 2011 at 10:29 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    You guys are all doing it wrong. :p
    SUA FTMFW!!!!
