Installing Lift!!
Discussion in 'Suspension' started by Tacompa, Aug 25, 2020.
  1. Aug 25, 2020 at 9:53 PM
    Tacompa
    Tacompa [OP] Well-Known Member
    San Jose, CA
    2019 Toyota Tacoma OR DCSB 4x4
    I'm installing this lift kit to my 3rd gen Tacoma.
    Fox 880-06-418 (w/ 14" 650 lb spring)
    Fox 883-26-006 (Tundra rear shocks w/ DSC)
    ICON Delta Joint UCA - ICON-58450DJ
    ICON Multi-Rate RXT Leaf Spring Kit 51101 (configuration #2)
    ICON Hydraulic Air Bump Stop Systems Rear Hydraulic Air Bumpstop System - 56103
    ECGS Needle bearing
    Any advice or good tutorials?
    I've reading and watching some videos and I think I'm ready. I'll be measuring from the middle of the hub to the fendor at ride height and at full droop. Then I'm going to go for 2" more of lift for a total of 3" of lift (2" lift + 1" stock lift height).
    jag624 and Island Cruiser like this.
  2. Aug 25, 2020 at 10:17 PM
    Bishop84
    Bishop84 Well-Known Member
    Dive in and ask for help as needed. Make sure you have a vice to install bushings as needed. Also check to make sure all the parts are ready to be installed.
    Tacompa[OP] likes this.
  3. Aug 26, 2020 at 2:11 PM
    Tacompa
    San Jose, CA
    Any idea how many threads I should have showing on the Fox 2.5 coilcovers (w/ 14" 650 lb springs), if I want to achieve 2" of additional lift? I know it will take some fine tuning based on my measurements but if I can get it close before installing it will be less of a headache.
  4. Aug 26, 2020 at 7:52 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Call me silly. I know the 3rd gen sits about 1” higher from factory then the 2nd gen. But if you remove the factory coilovers your basically at 0. setting you new coilovers at 2” is just 2” of lift not 3 because all the factory stuff is gone.
  5. Aug 26, 2020 at 10:32 PM
    Tacompa
    San Jose, CA
    I'm adding 2" of lift based on my measurements. For example if at stock height I measure 21" from center hub to fender, then I want to measure 23" after my lift.
