installing light racing uca's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07TaCo07, Jul 31, 2011.
  1. Jul 31, 2011 at 6:16 PM
    07TaCo07
    07TaCo07 [OP] Well-Known Member
    oregon
    07 double cab 6" lift
    6" fab tech lift, 35" toyo m/t, 17" teflon wheels
    I finally got my ucas and just waiting for the bolts from toyota, suppose to be here days ago but my dealer sucks big ones. Ill start after I get off work. I hope it goes smoothly.
  2. Jul 31, 2011 at 6:18 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    Decided to cheat and cut the heads off the long bolts? :rolleyes:
  3. Jul 31, 2011 at 6:24 PM
    07TaCo07
    oregon
    Yeah I feel like it might be less of a headach. Im more worried about getting the compression bolt out of the spindle
  4. Aug 1, 2011 at 12:50 PM
    TacoAlaMode
    TacoAlaMode Mr. Midlife Crisis
    Brian
    Huntsville AL
    10 DC LB MG 4X4 TRD Sport
    Icon Ext Coilover, Alcan Rear springs, Demello 3-Hoop Bumper and RockCrusher Sliders, Full tint 360', WeatherTech Floor liners and rainguards, Debadged, In Cabin 110 with 400w anytime, Diff breather mod
    I did my passenger side in 40 minutes, driver side in 20. I put a few notes in the LR group buy thread. For the spindle bolt, loosen the castle nut to be flush with the bottom of the bolt, spray some wd40 or similiar up through the bolt hole toward the ball joint and then tap on the castle nut from the side in different directions and it should pop loose pretty easily. We also used my floor jack to take some of the pressure off when pulling the spindle loose. No prying necessary. If you leave your sway bar connected, it will keep your spindle upright and you don't have to worry about your break line or traction sensors.
  5. Aug 1, 2011 at 4:04 PM
    BenWA
    BenWA Well-Known Member
    Seattle @ 0.9 Mach
    '06 Double Cab TRD Off Road 4X4
    Are new bolts necessary to install the UCA's?
  6. Aug 1, 2011 at 4:06 PM
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    They aren't, but some people have trouble maneuvering the old ones out, so they cut them.
  7. Aug 1, 2011 at 4:09 PM
    07TaCo07
    oregon
    So I don't need to disconnect swaybar? The thread I was reading said to, 1 less thing to unbolt would be nice. No u don't need new bolts, only if u cut the head off the old one so it is easier to take out
  8. Aug 1, 2011 at 6:28 PM
    TacoAlaMode
    Brian
    Huntsville AL
    If you are replacing just the UCA, the swaybar and tie rods can stay. If replacing shocks, swaybar and tie rods have to go. The best thing to do with the spindle if you are doing shocks is to ziptie it to the UCA so it can't drop away, use two zipties because that spindle is heavy.
  9. Aug 1, 2011 at 7:22 PM
    07TaCo07
    oregon
    Im not doing shocks. Thanks for all the help
  10. Aug 2, 2011 at 4:23 PM
    07TaCo07
    oregon
    I just finished and this helped so much especially jacking it up some. Just need the alignment tomorrow
  11. Aug 2, 2011 at 8:54 PM
    TacoAlaMode
    Brian
    Huntsville AL
    Glad it helped. I got mine aligned, but I'm going to need to have someone else do it. The place I went didn't adjust at the ball joint and my camber is a little to much. I have the lifetime alignment with firestone, just have to find one with a good tech.
  12. Aug 3, 2011 at 6:11 PM
    07TaCo07
    oregon
    It took 3.5 hours to align my truck. It kept drifting right and he was having a hell of a time getting rid of it while keeping it in alignment
