Installing lunchbox locker in front diff
Discussion in '1st Gen. Tacomas (1995-2004)' started by devinzz1, Feb 23, 2015.
  1. Feb 23, 2015 at 2:48 PM
    devinzz1
    devinzz1 [OP] Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    There any write ups on installing a locker in the front of my 96? Searching and I only come up with ones for the rear.
  2. Feb 23, 2015 at 4:25 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Not that I know it. Th front diff is a bitch compared to the rear though. Just more shit to remove.
  3. Feb 23, 2015 at 7:48 PM
    devinzz1
    devin
    2023 aclb trd or mt
    more? I was thinking unhook lbj, tie rods. pull cvs from diff, driveshaft, connectors, drop diff. from there im not familiar with the disassembly and reassembly.
  4. Feb 23, 2015 at 7:56 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Don't have to do the tie rods. Just pull the cvs like normal and drop the diff.
    It's just a pita. Major pain compared to the rear. And the clamshell is just odd.
    But yea not much too it. Go for it. I'd never run a lunchbox up front though unless you're manual hubs and even then probably would either.
  5. Feb 23, 2015 at 8:35 PM
    devinzz1
    devin
    2023 aclb trd or mt
    select able lockers like the arb are just out of my price range. Im really liking the no-slip in my rear end and ive been in a couple situations already where a front locker would have saved alot of trouble. From what i know the front axles are disengaged when in 2wd so it shouldnt cause any problems there. I will however take extra caution to not turn on pavement with 4x4 engaged if i end up getting one.
  6. Feb 24, 2015 at 10:21 AM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    Same here. Looking at getting an Aussie and changing the oil pan gasket when I'm in there.
  7. Feb 24, 2015 at 7:00 PM
    mrbeggins
    mrbeggins LOW.LIGHT.WIDE
    Tanner
    Airdrie Alberta
    04 Tacoma
    Do you have manual hubs or ADD?
    If you have ADD, and instal a lunchbox like the Aussie, you will essentially be in 4wd all the time. CV's turn, which in return turn your locker. When you go from 2hi to 4hi, all your doing in engaging the stubshaft. (The right axle).
    At least that's how I understand it....
  8. Feb 24, 2015 at 7:08 PM
    devinzz1
    devin
    2023 aclb trd or mt
    Is the front diff not dissengaged at the transfer case as well as the the front passenger cv?
  9. Feb 24, 2015 at 7:24 PM
    Brake Weight
    My understanding of the Aussie lockers and all other same style 'lunchbox' lockers is that they do not engage until power is applied. So as long as you're not in 4wd they will not bite. ADD nor manual hubs matter, albeit with ADD it will be spinning but the internal springs will keep it disengaged until power is applied.
    At least that's what I've researched and the reason I'm leaning that way. I can afford a normal locker, but in the front it doesn't really matter. A conventional locker is just another thing to maintain on: air or electric. The Aussie seems more worry free and being not as easy to access, tends to be a no brainier for myself since I don't have snow to drive in here. A rear conventional locker is easier to get at and more ideal for day to day driving.
  10. Feb 24, 2015 at 7:39 PM
    Blueitrgsr
    Blueitrgsr Well-Known Member
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    Some bilsteins, OME 885's, and an AAL.
    This would be my concern, i know all is dissengaged at the transfer case but everything is still turning inside the front diff albeit just not getting power. Would nothing inside the diff cause this to lock up on the pavement even when not in 4wd? And would it be that detrimental if it did?
  11. Feb 24, 2015 at 7:43 PM
    Brake Weight
    I've never been around one personally, but it's supposed to make ratcheting sound when disengaged and the opposing wheels aren't turning the same speed like when turning.
  12. Feb 24, 2015 at 7:50 PM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    On 2nd gens, the front diff is still in motion even if your 4wd isn't engaged so essentially, you would have your two front tires turning at the same speed, even when you're trying to turn.
    The only way that I know of to get around this is
    ARB locker which keeps your front diff as an open diff until you lock it using air,
    Or
    Buy a locking front diff from a Hilux and install it, and it would be an electronic locking front diff. Much like the rear locking diff on the TRD Offroad models
    Both are expensive and require a lot of work that probably isn't for a novice mechanic
  13. Feb 24, 2015 at 7:52 PM
    Blueitrgsr
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    Right, so nothing is keeping that lunch box locker from locking up essentially?
  14. Feb 24, 2015 at 8:05 PM
    Brake Weight
  15. Feb 24, 2015 at 8:11 PM
    Blueitrgsr
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    Me? A spool is locked up all the time and should only be used on a dedicated and trailered trail rig. These lunch box lockers lock up when one side starts to slip correct?
  16. Feb 24, 2015 at 8:21 PM
    Blueitrgsr
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    According to aussie they can be used in some part time 4wd front diffs. Atleast thats my interpretation of the statement.
    Constant 4WDs
    Like all automatic lockers, the Aussie Locker cannot be used in front axles of constant 4Wheel Drive vehicles. (such as a land cruiser) Some vehicle manufacturers offer a part-time 4WD option and automatic lockers can be installed. Some vehicle owners install part-time kits or use free wheeling hubs.
  17. Feb 24, 2015 at 8:25 PM
    Brake Weight
    Right. You wouldn't want to run these in an AWD vehicle. A hi/lo option would make it full time 4wd.
  18. Feb 24, 2015 at 8:30 PM
    Blueitrgsr
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    So essentially you could run one in the front of our trucks? Sure. I think drive-ability should be alright and would not risk hurting anything internally. Not necessarily something i would run in my front diff.
  19. Feb 24, 2015 at 8:44 PM
    Brake Weight
    Down south I don't think it'd be an issue. For our Yankee brethren using 4hi on winter roads, it's not a good option. Strictly offroad, it should be good to go.
  20. Feb 24, 2015 at 8:52 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    I would not install a LB locker in the front
    unless it had manual hubs/axles.
    Even then... one need be mindful of bind when articulating.
    If using ADD... an air locker is the smarter call IMO.
    Even though I still have ADD...
    Having manual hubs could keep the vehicle rolling
    even if a cv axle needed be removed.
    But with ADD...
    if ya needed remove a cv axle to get off the trail
    your hub/wheel would fall off before ya rolled 20ft
    and that would be bad... and could hurt.
    ADD is great if 4x shift on the fly is yer need...
    But IMO it's a terrible design for a dedicated off road rig.
