Installing Molle Panels - 3rd gen 4runner - **Pictures**
Discussion in '4Runners' started by ramonortiz55, Jul 6, 2017.
  1. Jul 6, 2017 at 11:01 AM
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    I was able to obtain a 3rd gen 4runner Rago Fabrication Modular panel for my rear side windows.
    These panels will require drilling trim and removing the back cargo panels for proper installation.
    I highly recommend:
    1. Beer.
    2. A friend to help you - This is not a solo job.
    3. Time - This is not a job you want to start after work, during the week. You will need at least half a day to install both panels.
    You will need a rivnut tool, a drill, a step bit that steps up to at least 3/4" diameter, and 1/8" pilot bit, and a 25/64" drill bit.
    The 25/64" drill bit is important since the holes for the rivnuts must be EXACT. I recommend making sure the rivnuts in the packaging are all the same diameter and the drill bit is sized accordingly. There can not be room for error here.
    Make sure you have a helper. Even if it is your feline.
    First order of business is to remove the rear cargo panels. The first thing to be removed is the hatch floor trim -
    Next, remove the top panel where the hatch light is at.
    This is done by removing the light cover:
    Removing the four screws and the bulb:
    Pry the lighting bracket away from the roof trim carefully and pull out the power plug:
    at the ends of the roof trim there will be two small brass screws, remove these as well:
    Now the top trim can be removed by pulling firmly:
    Next we remove cargo cover brackets, removing the visible bolts will release them
    The shoulder panel must now be removed (picture was taken before I removed the cargo cover bracket):
    To remove the shoulder panel, the door floor trim must be removed, locate two screws and remove the door floor trim by firmly pulling away.
    The shoulder trim can now be removed by pulling firmly. No screws are located on the shoulder trim.
    The main cargo panel can now be removed. In this case, the passenger side:
    We will now locate the TWO outer holes where the trim fasteners push into. In the picture below, you will see four holes below the window. It is the two outer holes.
    Pointing at the left and right hole respectively:
    Once they have been located - drill out the hole to the size of the rivnut:
    Use the step bit to de-burr the holes. We want nice clean holes to set the rivnut:
    Test fit and set rivnut:
  2. Jul 6, 2017 at 11:01 AM
    ramonortiz55
    Ramon
    Texas
    stock
    Drink Beer. Pet Cat.
    Next:
    A pilot hole will be drilled from the BACK end of the trim panel.
    Remember where the rivnuts are?
    The trim fasteners that were in this location are now obsolete. Remove them from their seats on the back of the panel. Use the center of the fastener seat to create your pilot hole.
    Grab the step bit and drill out to 3/4" hole, stopping periodically to check the fitment of the aluminum spacer. You want a nice snug fit. Don't over drill. Be patient.
    You can barely see the rim of the fastener seat thru the hole. Use it to make sure you are centered.
    Test the spacer for a nice, snug fit.
    This is what the back end will look like:
    Once the hole in the trim is complete - it will be centered against the rivnuts:
    Drill your second hole and install the panel, yes. INSTALL it. Make sure all the fasteners clip in place. Make sure it doesn't wobble. Make sure it is set to STAY. You will see why. This is important.
    Install the top brackets on the modular panel:
    Install modular panel (top brackets not shown here):
    Side view for clarity:
    Next make sure your friend is holding the panel to where the brackets are away from the window - I have it about a 1/4" clearance.
    Use the slotted holes in the bracket to center the pilot bit, drill thru the trim and mark a location in the metal beyond the trim. This will locate where the rivnut goes.
    Next, drill out the trim hole with the step bit in the same manner as mentioned before, drill your hole for the rivnut and set rivnut.
    The finished spacer install should look like this:
    Once the second location has been drilled and set, the panel can now be installed:
    Same installation procedure for the passenger side:
    Install goods and enjoy!
  3. Jul 17, 2017 at 9:39 AM
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
    This is on the get list. How are they holding up so far? Do they handle a bunch of crap with ease?
  4. Jul 17, 2017 at 9:52 AM
    ramonortiz55
    Ramon
    Texas
    stock
    So far, they have held up well!
  5. Jul 17, 2017 at 9:53 AM
    Riding Dirty
    PlastiDip
    Awesome! I can't wait to be able to order some!
  6. Jul 21, 2017 at 8:14 AM
    rkntoy
    rkntoy Well-Known Member
    Bend, OR
    Any way you could post a pic looking back from the front seat? Been thinking about doing one of these to pair with the panel I made for my ceiling.
  7. Jul 21, 2017 at 8:25 AM
    ramonortiz55
    Ramon
    Texas
    stock
    Yes, remind me on August 12th.
    I'm away from my 4runner at the moment
  8. Jul 21, 2017 at 8:26 AM
    rkntoy
    Bend, OR
    Will do.
  9. Jul 21, 2017 at 8:29 AM
    Phoosa
    Phoosa I never saw nothing.
    Truck
    That looks good. Clean install.
  10. Jul 21, 2017 at 8:34 AM
    ramonortiz55
    Ramon
    Texas
    stock
    thanks!
  11. Jul 21, 2017 at 8:38 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Holy crap that's cool.
