Installing my engine. Need help
Discussion in 'Technical Chat' started by BackwoodsTaco, Jan 10, 2013.
  1. Jan 10, 2013 at 10:19 AM
    BackwoodsTaco
    BackwoodsTaco [OP] Well-Known Member
    Paul
    Stokes, NC (Eastern NC)
    Radiant Red 01 DC, 4X4, SR5, Supercharged
    TRD Supercharger, URD 7th injector kit, TRS RetroFit, Deck Plate Mod, No Chime Mod, Fog Light Mod, CB/ashtray Mod, 2.5" Spacer Lift, 1.25" Lift Shackles, 4 Tab Light Bar From Eddie209
    I was wondering if there is a trick for getting the tans to line up with the engine so do not have to remove the trans. I tried for 2 hours last night to get it to line up but it just wouldn't go together. my trucks been down for almost 2 months :( and I'm ready to get back up and running. So please give me some good news guys.
  2. Jan 10, 2013 at 10:23 AM
    98tacoma27
    98tacoma27 is gooder 'en chicken Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+250k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Define "won't go together".
    How close do they get?
    Are they aligned vertically but won't slide together?
  3. Jan 10, 2013 at 10:32 AM
    BackwoodsTaco
    Paul
    It's like I can't get them to come together the trans was sitting to low so I jacked it up but still had the same problem and the engine mount won't line up
  4. Jan 10, 2013 at 10:33 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Is the torque convertor still on the trans or mounted to the flex plate on the motor?
  5. Jan 10, 2013 at 10:35 AM
    BackwoodsTaco
    Paul
    The torque converter is still in the trans
  6. Jan 10, 2013 at 10:43 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    You may have to loosen the trans up and put it on the motor. I've had more luck that way. The trans is easier to jostle around than a motor. Unless someone else has a trick. :notsure:
  7. Jan 10, 2013 at 10:48 AM
    BackwoodsTaco
    Paul
    so my best bet is to remove the trans :(
  8. Jan 10, 2013 at 10:52 AM
    TherealScuba
    TherealScuba Well-Known Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    Just remove the mount from the crossmember.
    Then you can move it around as much as you need.
  9. Jan 10, 2013 at 11:01 AM
    BackwoodsTaco
    Paul
    Ok thanks guys
  10. Jan 10, 2013 at 8:58 PM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    They are not the easiest to line up, that is for sure. One thing that I have done that helps is take one of your transmission bolts to a hardware store and buy 2 bolts of the same thread, but that are around 4 to 5 inches long. Cut off the heads and thread them into your engine. then use them as aligning pins to line up the transmission. I have about a dozen bolts like that for different engines.
  11. Jan 11, 2013 at 9:07 AM
    Failure2Comply
    Failure2Comply Well-Known Member
    Virginia, USA
    05 Access TRD/SR5 4x4
    NFab bars, bed mat, Weathertech mats.
    That is a great idea!
