Installing My Lift in Stages.....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jmed99, May 13, 2010.
  1. May 13, 2010 at 4:35 PM
    jmed99
    jmed99 [OP] Well-Known Member
    SC
    09 DC PreRunner TRD OR
    I don't want to be rushed so I'm going to install my lift in stages. I'm thinking about the following stages with possibly a week in between each stage.
    1st) Put on the AAL and rear 5100s
    2nd) Install TC UCAs
    3rd) Front preassembled coilovers
    4th) 285/70/17s
    Can I ride around with the entire front completely stock except for the TC UCAs with rear AALs and 5100s installed? I don't see a reason not to but thought I should ask.
    Am I missing anything?
    Thanks! :cheers:
  2. May 13, 2010 at 4:36 PM
    MOT
    MOT Prez of @BattleBornToyotas
    Daniel
    Las Vegas
    08 DB DC 4X4 Sr5 Sport
    Black Housing Head, Custom Retro fit, T-Rex #2 Eyelids 50 inch ToughLight Radius Bar and 2 20 inch Bars behind grill with BAMF mount, T-Rex #2 Eyelids, Custom Vegas Dezert Fab Front Bumper and Rock Sliders,Wet Okole's, WeatherTech Mats, Magnaflow Exhaust, Pro Comp 6 InchStage 2 Lift, K&N Intake,
    Just take a weekend and do all of it bro!
  3. May 13, 2010 at 4:39 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    Well, the front struts have to come out to install the UCAs, so you might as well install the new ones at the same time.
  4. May 13, 2010 at 5:29 PM
    whitebread
    whitebread Well-Known Member
    Raleigh, NC
    2011 4x4 DCSB TRD Off-Road
    Leer 100XL and a bunch of off-roading scars.
    No they don't. You just need to support the spindles when the UCA is removed so it doesn't hang on the brake line. Absolutely no need to remove the dampers.
  5. May 13, 2010 at 5:39 PM
    meafordmike
    meafordmike Well-Known Member
    New Brunswick Canada
    08 Tacoma 4X4/ 4Dr 6 speed, Sport/ Towing
    Devil Horns, Wet Okoles, WeatherTechs, Radflo Coilovers, OME Dakar's, FJC Gun metal rims, 265/75/16 BFG All Terrain TA/KO, Rear Diff breather Mod,
    I did it kinda like that. Istalled tires, 2 weeks later installed new dakar's and OME N182, then 2 weeks later put the front coilovers and UCA on.
    No problems, but as someone else said if your doing UCA's is simple to do coilovers then.
  6. May 13, 2010 at 5:42 PM
    JDMcQ
    Now that I think about it, I guess that is right. I stand corrected. Thanks for the info.
    The front struts are pretty easy to replace though (at least on my 1st gen). Do it while the wheels are off, I think.
  7. May 13, 2010 at 5:57 PM
    jmed99
    SC
    Is it ok to ride around with just the TC UCAs on the front with no other mods on the front?
  8. May 14, 2010 at 5:00 AM
    jmed99
    SC
  9. May 14, 2010 at 6:33 AM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    no, you will blow out your wheel bearings....
  10. May 14, 2010 at 8:36 AM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Since you're talking about doing the mods only one week apart, I think I'd just do the whole front at once. From what I've seen, the coilovers swap out pretty quickly, especially since you're already in there. It'd be less work plus you'd probably have more room to work on the UCAs without the coilover in there.
  11. May 14, 2010 at 3:36 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    If you do UCA's, you might as well do the coilovers and wheels at the same time. You've already got the truck up, the tires off and the tools out.
    Another thought... you'll need an alignment after just doing the UCA's. You'll also need an alignment after only raising the suspension. Might as well just do both at the same time, install the larger tires and get the alignment done once.
    I did mine over the period of 1 year. Suspension w/o UCA's... needed an alignment. Then did the UCA's... needed another alignment. Don't make the same mistake.
  12. May 14, 2010 at 3:43 PM
    JDMcQ
    This is a good point. You really should get an alignment after doing the rear as well. Lifting it changes the caster in relation to the ground and the weight on the front end as well.
  13. May 14, 2010 at 3:48 PM
    Brunes
    Brunes abides.
    Rotorhead
    I did all the same things you are doing (less the tires) in about 6 hours. I would get as much done at once as possible if it were me. Less effort to align it and make sure they are right....Plus you'll find out if you need anything else to eliminate shims or anything...
  14. May 14, 2010 at 4:00 PM
    jmed99
    SC
    I get free alignments so that's not a factor.
  15. May 14, 2010 at 4:07 PM
    deejaecee
    deejaecee Well-Known Member
    Bay Area
    10 4X4 Double Cab Sport
    All that can be done in less than 8 hours taking your time. When I did my install it took around 7 hours with us takin our time and going to the store to get parts.
  16. May 14, 2010 at 4:13 PM
    Brunes
    Brunes abides.
    Rotorhead
    If sitting around waiting for the alignment and/or doing them over and over yourself is okay with you- Then swing it any way you want!!!
    The UCAs shouldn't hurt you on the stock front end...and with a good alignment you should be able to drive just fine with each of those changes...
