Installing new leaf spring-make sure I'm doing it right!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dinah870, Nov 21, 2019.
  1. Nov 21, 2019 at 10:09 AM
    dinah870
    dinah870 [OP] Member
    2014 Tacoma DCSB 4x4 Baja
    Hi all,
    Going to be installing new leafs on my 2014 T/X baja. The wife and I are purchasing a RTT trailer and it's finally time to get rid of the stock aluminum foil leaf springs. Truck sits about 2 inches low in the rear and I've been putting it off, but finally have a reason to change them. Looking at this package here:
    https://www.alldogsoffroad.com/old-...MI_Zaahej75QIVlCCtBh1yDQUVEAQYASABEgKDZ_D_BwE
    I will be installing them and want to make sure this kit will have everything I need. Trailer will have about a 150b tongue weight, and I'm hoping with the medium springs this will allow the truck to sit level when attached to the trailer. Do I need any other parts? Any recommendations on install or advice for those who have done it before? I'm fairly new to this and want to make sure I do it correct the first time. Thanks!
  2. Nov 21, 2019 at 10:19 AM
    dinah870
  3. Nov 21, 2019 at 10:22 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    That's got nothing to do with alignment whatsoever. I suggest you research research, then research some more. Carrier Bearing Drop Kit is to correct driveline angles.
  4. Nov 21, 2019 at 10:24 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    You should order it all from Marie at Headstrongoffroad.com or Wheelersoffroad.com
  5. Nov 21, 2019 at 10:38 AM
    dinah870
    Sorry thats what I meant. Not wheel alignment.
