Installing rack on canopy...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 08TacomaDC, May 6, 2011.
  1. May 6, 2011 at 10:38 PM
    08TacomaDC
    08TacomaDC [OP] Member
    08 double cab sr5 4x4
    I have a snugtop canopy on my tacoma that has no rails or rack whatsoever on top. It's just a slick painted surface. Well, I now need a roof rack. Is there a way to install one to this type of canopy?
  2. May 7, 2011 at 4:29 AM
    Tim A
    Tim A Well-Known Member
    Montana
    2011 TRD Offroad 6 spd Double Cab
  3. May 7, 2011 at 6:57 AM
    GuapOh
    GuapOh Well-Known Member
    Nor Cal
    2011 SR5 4x4 MT
    Skid Plate, Hood Protector, Wheel Locks, Snugtop XV, Yakima Rack, Weathertechs, Sick Speed Shifter, Avid Bumper, Avid Sliders, Bilstien 5100's, TSB Spring packs
    Before you drill it, consider taking it to a Snugtop dealer for them to do it or send it back to Snugtop for the installation. I know it's a hassle but if you penetrate the 'glass, you void the lifetime warranty which Snugtop offers.
  4. May 7, 2011 at 8:54 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    This ^^^
  5. May 7, 2011 at 8:56 AM
    tanzak88
    tanzak88 Well-Known Member
    Penetrate......... :D
  6. May 7, 2011 at 9:04 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Also, if you have never drilled into a gel coat or fiberglass, make sure you get the right drill bits, or you will have cracks and chips with every hole drilled :eek: It could get ugly...
  7. May 7, 2011 at 12:56 PM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    I installed a Yakima track system on my ARE shell. Yakima includes instruction on how to install them but in a nutshell:
    Measure out where you want them; you don't want to drill through the center reinforcing honeycomb section on most tops.
    Mark your holes them drill a small pilot hole before switching to a larger bit; putting tape on the hole should help prevent chipping. Use a new (or at least sharp) drill bit; I like the ones with a pilot tip.
    Use a small amount of silicon on the bolt/in the hole and install the tracks.
    Install risers/bars and enjoy.
    Mine has been on since 2006 and I've carried around 150#s on it more than once in varying combinations of canoes, kayaks, bikes and lumber and so far no leaks.
