Installing rapter lights and fuse taps??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TheTacoProject, Aug 22, 2025.
  1. Aug 22, 2025 at 12:46 AM
    TheTacoProject
    TheTacoProject [OP] Active Member
    New York
    2023 SR5 Tacoma
    So I'm looking to install the OEM TRD pro grille on my SR5 Tacoma, Im doing raptor lights too and I was gonna do the generic add a fuse, fuse tap into INJ fuse however I've encountered a problem. I have the morimoto headlights the XB EVO's, they are already tapped into the INJ fuse for DRL's. I wanted to know if there's another fuse to use? I debated EFI but know then they may turn on due to a power cycling known to go with said fuse. Wanted any input from anyone who may be more proficient in auto electrics and which fuse would act the same as DRL, power wise, on all the time without headlights but also turns off with the truck. I also am avoiding splicing the DRL wire and connecting them to that as that's not ideal but will consider if no other options seems reasonable.
  2. Aug 23, 2025 at 6:33 AM
    Oldgray1
    Oldgray1 Member
    2020 Sr5
    Can you tap the parking light fuse?
  3. Aug 24, 2025 at 11:22 AM
    itsnotatoy
    itsnotatoy Well-Known Member
    Tom
    NW Valley AZ
    2023 Tacoma DCSB ICE CAP TRD Sport Premium & Tech Pkg
  4. Aug 25, 2025 at 5:56 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    I would install a small relay and activate it off the accessory power signal. That way you can put as many lights as your little heart desires on that truck. But if you are just running the raptor lights and DRL's, you would be just fine splicing both the aftermarket lights in with the INJ fuse tap.
