Installing rear 5100's lil help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MxRacer190, May 2, 2010.
  1. May 2, 2010 at 8:47 AM
    MxRacer190
    MxRacer190 [OP] Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    Which way do the bushings go on the top of the rear shock? The instructions for the rear didn't come with my shocks :(
  2. May 2, 2010 at 9:08 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    A washer goes on the shock shaft first, then a bushing, then another washer, then insert it thru the mount, then a bushing, then the last washer.
  3. May 2, 2010 at 7:22 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    And if you look closely, you'll see that one of the washers is lighter weight than the other 2. Put this one in the "red" location noted above.
  4. May 2, 2010 at 9:11 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    yup, what they said
  5. Jul 6, 2010 at 5:43 PM
    Devildoc
    Devildoc Well-Known Member
    Lincoln, California
    Speedway Blue off road
    Running board, K&N air filter, Nitto Terra Grapplers G2 on ProComp 7089(285/70/17), 3" front lift and 1.5" AAl rear, all with bilstein 5100's with Eibach spring, 1/2 spacer in driver side and 1/4 spacer on the passenger, Wicked Flow exhaust, Debadge, satoshi raptor grille (HomerTaco)
    Your the best Chris!
  6. Jul 6, 2010 at 5:43 PM
    Devildoc
    Lincoln, California
    Your the best Moose!
