Installing Resistors for LED Turn Signals
Discussion in 'Lighting' started by RDBarker, Jan 18, 2014.
  1. Jan 18, 2014 at 5:39 PM
    RDBarker
    RDBarker [OP] New Member
    Randy
    Chugiak, AK
    2010 Tacoma TRD Sport
    Running Boards, Bed Cover, Remote Start
    I have a 2010 Tacoma and want to install LED Switchbacks for my front turn signals and DTRLs. Where is the best place to install the resistors and what is the best method to fasten them? I'm a newbie to this type of stuff and need some good ideas. Thanks
  2. Jan 20, 2014 at 8:48 AM
    lilgerber
    lilgerber Well-Known Member
    Aaron
    Fresno, CA
    06 4x4 off road Speedway blue
    Front: Total Chaos 3.5 4x4 LT kit, Engage off-road one piece hood, Caged front end, TC gussets. Rear: Fiberworks fenders, King 14" 3.0 triple bypasses, boxed/braced frame, extended brake lines, 63" chevy leaf springs, U bolt flip kit, TC lower shock mounts. Preformance: URD intake, Doug Thorley headers, Flowmaster 40, 2.5 tubing. Interior: Weather techs, LED's, Double DIn, kicker 10" subs, Kicker componet speakers, Exterior: Method wheels with OMF beadlocks, Custom made bumpers, Retro headlights.
    I was also wondering the same thing. Anyone?
  3. Jan 20, 2014 at 3:42 PM
    stephbm6
    stephbm6 Well-Known Member
    West Jordan, Utah
    2019 TRD OR Double Cab
    I did my back turn signals and the resistors get really hot real fast that's why I haven't done my front turn signals. I have DTRL's and I've heard that the resistor wires melt because of the heat from being on all the time.
  4. Jan 20, 2014 at 3:47 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I did my rear turn signals LED and I double sided sticky taped the resistors on the metal body of the truck where the taillights are. Not sure how good that would hold up on plastic though since they can get super hot.
  5. Jan 20, 2014 at 3:48 PM
    gman2530
    gman2530 Well-Known Member
    San Diego, Ca.
    04 PreRunner
  6. Jan 20, 2014 at 3:55 PM
    stephbm6
    West Jordan, Utah
    I actually drilled and screwed the resistors into mine to help disperse the heat.
  7. Jan 22, 2014 at 2:27 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Meh mine just hang off the wires and are ziptide lol
  8. Jan 22, 2014 at 2:32 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Do you have a pic of the resistors? Are they mountable?
    Any METAL surface will conduct the heat.
    There is also a conduction paste available-"HEAT SINK COMPOUND"-It is cheap and should help.
  9. Jan 22, 2014 at 2:40 PM
    BamaToy1997
    Bill
    Navarre, FL
    I don't use any resistors. I bought the LED flasher module that eliminates the need for resistors. I would look at SuperbrightLED.com for their flashers. This is a list of the ones they have: Flasher modules.
  10. Jan 23, 2014 at 2:35 PM
    stephbm6
    West Jordan, Utah
    Could you show where you plug these in at?
  11. Jan 23, 2014 at 2:44 PM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    That won't work for DTRL trucks right? We would need a 12 pin flasher for DTRL's to still work.
  12. Jan 24, 2014 at 10:04 AM
    BamaToy1997
    Bill
    Navarre, FL
    You just put it in place of your turn signal flasher. It replaces the factory one.
    I believe someone makes the flasher for the 12 pin DTRL Toyota. I will see if I can find the seller. It was a website that I found it on. Maybe Google "Toyota led flasher" and search around.
  13. Jan 28, 2014 at 6:19 PM
    MyMistress
    MyMistress Well-Known Member
    TN
    10 TRD Sport 4X
    Leveled front, TSB rear, TSB Transmission, Always on fog lights, Socked windshield / bedsides, Trimmed mud flaps, Weather Techs, 4 Extra d-rings, Map Light Mod, Avid Light Bar, OEM Bed Mat, Locked Back Window, Secret Stash Area,
  14. Feb 15, 2014 at 4:03 PM
    ZEROPILOT
    ZEROPILOT Can't re-MEMBER
    ED
    SUNRISE,FLORIDA
    09 2.7 XTRA CAB 5 SPEED
    LARGER WHEELS. DIFFERENT STEREO. PUSH BAR. TAILGATE EXTENDER. WIPER MOD. TPMS LIGHT DELETE MOD.
    Do the flasher mod. Its simple.
  15. Feb 16, 2014 at 10:44 AM
    lilgerber
    Aaron
    Fresno, CA
    Details on flasher mod?
  16. Feb 16, 2014 at 10:49 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    +1 Resistors are rated in Ohms of resistance - but there's a secondary rating which is their current capacity.
  17. Feb 16, 2014 at 10:56 AM
    916TacoTruck
    916TacoTruck BallzDeep is how I go
    Inyo mom
    2019 Rapturd
    Former 2013 TRD OR. Sickass edition
    Wattage rating is key when you have heat issues with a resistor. They come in 1/4 1/2 1 watt ratings.
  18. Feb 16, 2014 at 12:47 PM
    ZEROPILOT
    ED
    SUNRISE,FLORIDA
    I can't drag the link. There's a whole long post on it. You remove the flasher and grind about half of the resistor loop down. It works great. Look for my post."LOOKING FOR LED 1437 BULBS" TRY: http://www.tacomaworld.com/forum/2n...]256783[/ATTACH] [ATTACH=full]256784[/ATTACH]
  19. Feb 20, 2014 at 2:28 AM
    ZEROPILOT
    ED
    SUNRISE,FLORIDA
    An update. The flasher mod is NOT ideal for models 2009 and up with Daytime running lights. It will only work when the DTRLs are not lit. (in my case) I've done the DTRL delete now. No more DTRLs and no more issues.
  20. Mar 7, 2014 at 1:23 PM
    j0sh
    j0sh Well-Known Member
    Oklahoma
    '10 TRD Sport 4x4
    AFE Filter, TRD Catback
    Mine work fine. I would guess you didn't take enough material off of the loop.
