installing roof rack with light bar
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Chrischandler71, Mar 4, 2021.
  1. Mar 4, 2021 at 8:15 AM
    Chrischandler71
    Chrischandler71 [OP] Well-Known Member
    Athens, Georgia -Go Dawgs!!!!!
    2017 Tacoma TRD OR
    Lift, grill, tires, wheels
    I bought a Martin Offroad roof rack, and a light bar to go on the front. For you that have done this, should I install the rack, and then add the light, or put the light on before i place it on the roof? I will be installing it by myself, so wanted to keep rack lite to make it easy to place on the roof.
  2. Mar 4, 2021 at 8:37 AM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    rack first, lights after
  3. Mar 4, 2021 at 9:37 AM
    dave5623
    dave5623 Well-Known Member
    2020 TRD Pro
    I would suggest doing a test dry fit on the ground first just so you even know it'll fit and how the brackets should be placed. You could even attach whatever hardware you can while on the ground.
    Then install the rack and then the light bar.
  4. Mar 4, 2021 at 10:08 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Test route your light bars wiring also incase there is a spot where the rack is in the way of where you want to run the wires.
