installing scc1 in 04 regular cab...
Discussion in 'Audio & Video' started by brelandt, Mar 21, 2012.
  1. Mar 21, 2012 at 8:28 AM
    brelandt
    brelandt [OP] Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    Ordered a new HU and SCC1 for my 04 regular cab. Searched all over the internet for an example of where to mount the SCC1 and run the antenna but came up with nothing.
    Since the stuff has not arrived I have no idea how long the cables are but I was thinking of running the antenna wire up the back of the cab (behind some trim and headliner) and mounting it to the roof above the high mounted brake light and the SCC1 box somewhere under the bench seat or passenger kick panel.
    Anyhow, can anyone give me some guidance before hand? Thanks.
  2. Mar 26, 2012 at 11:26 PM
    sun
    sun Well-Known Member
    Memphis
    2011 PreRunner
    Pioneer avic-z130bt with axxess aswc and rear cam mod, audiovox 10 flip down monitor, Pyle pl76d headrest monitors, kicker cvr tens wired down to one ohm with hifonics Brutus 1200.1, Clazzio seat covers, 20% tint on front windows, polished factory exhaust, peragon retractable bed cover, pop n lock tailgate handle with dei actuators for automatic lock, viper 5901 alarm remote start with viper smart start, hid bixenon 4500k headlights with 4500k fog lights, led map license plate lights and dome lights
    The ant is like 20 ft long very easy to mount on rear of cab lol
  3. Mar 27, 2012 at 7:34 AM
    brelandt
    Terry
    Dublin, CA
    thxs for the reply. my package ought to arrive today. next day off is friday, so I'll start laying it all out.
  4. Mar 30, 2012 at 4:30 PM
    brelandt
    Terry
    Dublin, CA
    OK, installed the unit today. Just posting feedback incase someone in the future wants to know how I did mine.
    Placed the Satelite antenna on the roof just above the windshield. I had a new windshield installed and the rubber appears bigger than the original one and so tucking the wire behind it was super easy. Not sure if the stock would be the same or not. Ran the wire down the "A" pillar on the passenger side and tucked it around the square rubber block where the pillar transitions from the door frame. Ran the wire under and through the black molding next to the dash and then down to the top of the kick panel. Removed the door seal trim and pulled out the kick panel. I found a nice area up high and towards the foot well just behind the clearish plastic trim that has an arch with 1 connector on it. I just wrapped the extra bit of wire and tucked it into the arched trim piece. Ran the main wire from the SC-C1 to the radio up and over the steel bar near the radio antenna wire that feeds to the fender.
    I did not use any screws or tape to hold the SC-C1 down. The area it's in, holds it really well. So, no need for any of that unless you just want to.
    The rest of the install is standard for any other Tacoma.
    Loving it!
