installing slimcubby's HID kits???
Discussion in 'Lighting' started by TRDfarmerTN, Apr 20, 2009.
  1. Apr 20, 2009 at 7:55 AM
    TRDfarmerTN
    TRDfarmerTN [OP] Well-Known Member
    20% tint, painted handles,painted grill, wet okole seatcovers,sockmonkey decals
    i just got my HID heads & fogs from slimcubbys group buy and wanted some info on installing them....each set had some blade connectors from them thats a black wire & a red wire, the fogs connectors like that are smaller & longer, but where do both these connectors go on each kit?
  2. Apr 20, 2009 at 8:03 AM
    TacticalBacon13
    TacticalBacon13 Sorry for party rockin'
    Dunk
    Beech Creek
    2014 tundra platinum
    baby seat and a muffler
    if im correct red goes to the battery and black is grounded somewhere. send slim a pm and he will help you out!
  3. Apr 20, 2009 at 9:15 AM
    TRDfarmerTN
    they dont look like big enough ends to connect to the battery...on one set they might be 1/4 in. wide and the other set there maybe 1/16th wide...
  4. Apr 20, 2009 at 9:34 AM
    TacticalBacon13
    Dunk
    Beech Creek
  5. Apr 21, 2009 at 2:41 PM
    TRDfarmerTN
    install was pretty simple, except for some reason on the driverside headlight plug the spade connectors that you stick into the oem plug would stay in good, so u just cut the wire from the ballast and from the OEM plug and just wired them together...works great now! fogs were straight forward, hardest part was the little room to work with and finding a place to mount the ballast! so in conclusion it was a easy install except for have to cut &wire into the oem wiring on the driver side, but that just took maye 5min extra....ill try an get pics sometime this week though!
