Installing Spiker Hood Struts - I want to remove my stock hood prop
Discussion in '3rd Gen. Tacomas (2016-2023)' started by S550ilver, Apr 22, 2020.
  1. Apr 22, 2020 at 10:45 AM
    S550ilver
    S550ilver [OP] Well-Known Member
    Bartlett, TN
    2019 Tacoma Double Cab TRD Off-Road
    ICON Stage 5 Lift, 18x9 Fuel Shok, Nitto Ridge Grappler 285/65/18 tires
    I would like to remove the stock hood prop on my Tacoma after I install my Spiker Hood Struts just to clean up that area under the hood. Has anyone removed it and if so was it difficult?
  2. Apr 22, 2020 at 11:53 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    install the struts, remove the prop rod. pretty easy. Ski
  3. Apr 22, 2020 at 11:54 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Leave the prop rod, its not in the way or causing any damage. If your struts fail, then you will want it there to hold up the hood.
    Tallgrass05 and ksanti808 like this.
  4. Apr 22, 2020 at 12:01 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I left mine in.
    Devious6 and svermilyea like this.
  5. Apr 22, 2020 at 12:26 PM
    S550ilver
    Bartlett, TN
    Yea I get that part. But how does the stock prop rod come out? Just sldie it through the mounting location on the radiator support?
  6. Apr 22, 2020 at 1:03 PM
    skidooboy
    central lower mich
    yep, slide it out of the retainer/pivot. Ski
    S550ilver[QUOTED][OP] likes this.
  7. Mar 5, 2022 at 2:55 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I know its an older thread but I added the Spikers, removed the pop rod. Looks way better and also put a black plastic tab and removed the retainer clip. I just think it gives a cleaner look. I had the REdlines on my mustang and they are going on 14 years and npt an issue however I think the Spikers are of better quality but would be happy with either.
  8. Mar 5, 2022 at 5:48 AM
    TheSortaHawaiian
    TheSortaHawaiian Well-Known Member
    21 Lunar Rock TRD Pro
    Why remove it? Leave it for when the struts fail. Just an ocd thing?
